my vespa has numbers on the motor: VIN 033467 and under the left side compartment: VN12T 031396. can someone tell me the exact year. when i imput the VIN on the "vespa motor number search page", it comes up '48-'50, just wanted to know for sure before i register with d.m.v. thanks
thanks...
jamesjohn wrote: You have a 1955 Vespa 125 motor |
Picture might be help
I guess that's not vn12t but vnl2t... Vespa 50' not located vin number under the left side compartment... |
guess that WOULD help...
my first rat...and i'm loving it!
![]() ![]() ![]() lucky rabbits foot...for luck it will start!
![]() ![]() ![]() ![]() beauty shot
![]() UTC
'80 Bajaj Chetak; '65 Vespa V90; '59 Lambretta Li125
Posts: 492 Location: St. Louis, MO |
![]() '80 Bajaj Chetak; '65 Vespa V90; '59 Lambretta Li125
Should be a '61 or '62, given that it's got the Cushman badge. Very nice, those Cushman Vespas are relatively rare.
engine number
Valimagdon wrote: Should be a '61 or '62, given that it's got the Cushman badge. Very nice, those Cushman Vespas are relatively rare. |
![]() UTC
Re: engine number
m. wrote: Valimagdon wrote: Should be a '61 or '62, given that it's got the Cushman badge. Very nice, those Cushman Vespas are relatively rare. Now, you may have a '61 frame w/ a '55 engine. You can pull the engine cowl off and show us some pics of the engine. VNB/VBBs were the first of the rotary inducted engines and came out in '57/'58; a '55 engine would be piston ported. You can tell by looking at the cylinder/carb placement. That scoot is most def a VNB/VBB. If the 125cc displacement is correct, then it's a VNB. But then again, the '55 motor would be a wideframe motor, which wouldn't be a straight swap into a VNB/VBB. |
veloce75 wrote: well... that's likely 1961 VNB2 :roll: check the engine number on the swingarm Valimagdon wrote: Should be a '61 or '62, given that it's got the Cushman badge. Very nice, those Cushman Vespas are relatively rare. Also regarding the numbers. On both the frame and the engine there is a prefix then there will be a star, then the number, and one more star. when identifying the bike the prefix is more important than the number. The prefix will narrow it down to a few years. The prefix + number will give you the specific year. But the number alone is meaningless. Given that the bike is a largeframe puts it at '59 or later. The choke is next to the fuel meaning it's not a VNA. Judging from the front drum, front fender, and vespa badge it's a 125 and not a 150, add the cushman badge brings it to '61-'62. The prefix you gave "VN12T" looks right except for the 3rd digit and 50 years of dirt can easily make a B look like a 1. So you should find the following prefix and number on the frame and engine. Frame: VNB2T *031396* Engine: VNB2M *033467* It's a good idea to include the prefix with the DMV to avoid them saying "031396 is registered in Nevada and is a chriscraft boat, not a vespa." So your VIN would be entered as "VNB2T031396" And the motor number (assuming your state uses it) would be "VNB2M033467" |
Quote: You have a 1955 Vespa 125 motor |
Re: engine number
Valimagdon wrote: m. wrote: Valimagdon wrote: Should be a '61 or '62, given that it's got the Cushman badge. Very nice, those Cushman Vespas are relatively rare. Now, you may have a '61 frame w/ a '55 engine. You can pull the engine cowl off and show us some pics of the engine. VNB/VBBs were the first of the rotary inducted engines and came out in '57/'58; a '55 engine would be piston ported. You can tell by looking at the cylinder/carb placement. That scoot is most def a VNB/VBB. If the 125cc displacement is correct, then it's a VNB. But then again, the '55 motor would be a wideframe motor, which wouldn't be a straight swap into a VNB/VBB. ![]() ![]() ![]() |
The split headset was on Vespas and Allstates in '58 and '59 also. It's definitely a bit of a unique scoot you've got. Not necessarily worth more money than other VNBs but with the Cushman badge, some think they're worth a bit more than others.
oopsclunkthud wrote: Quote: You have a 1955 Vespa 125 motor |
year?
jamesjohn wrote: oopsclunkthud wrote: Quote: You have a 1955 Vespa 125 motor |
m. wrote: jamesjohn wrote: oopsclunkthud wrote: Quote: You have a 1955 Vespa 125 motor Btw...this is not a 250cc. Likely a 125. |
