is it unscreewed in bottom or upper if its in buttom thats simple but if its in upper u need to take off ur gas tank brother
cheer and good luck
hmmm well i unscrewed the nut under the gas tank and then starting turning the shock until it came off...!? im going to go for a ride right now... i will get back to you..!
Once you have unscrewed the thread of the shock out as far as it will go so the threaded portion is at maximum, there is a 9mm sprung washer that goes between it and the block (me I always put loctite on the thread as well)or it will unscrew quite quickly.
