Copper Dolphin wrote:
Glad to hear it was not something in the engine. The variator nut coming loose is a direct effect of them not mounting the belt properly. They probably just slapped the belt on, and used the airgun to tighten the nut, without pulling the belt down into the clutch pullies. Hence leaving the belt to get in the way of the variator halfs coming together fully. A loosened Variator Nut, will almost always cause damage, by letting the variator bang into things. Did they let you see inside? (before and after repairs) {Sorry I am super suspicious of mechanics} Did they replace the variator?? or any other damaged pieces?? to include the Trany housing it's self??
Ouch $218 for an oil change service, I am glad I do it myself....
All in all I am glad your back on the road, riding your great scoot everywhere you can!!
If I read it correctly, the scooter was brand new with just a few hundred miles on it. The dealer had no reason to pull the variator apart, therefore, they wouldn't have slapped the belt on and hit it with an airgun.
The first service involves more than just an oil change and usually runs around $160, so the $218 is a bit high, but may be in keeping with the area he lives in. Some parts of the country are higher in dealer fees.
