Yeah go ahead and laugh at me..!!!! I striped my god damn headset bolt trying to put my drops in..!!!
Further update
So i got a new bolt and nut and put it through the headset and tightened the hell out of it... and If i put my legs between the front wheel i can move the headset slightly... what could be the cause of this!!?
DominicLNanni wrote: So i got a new bolt and nut and put it through the headset and tightened the hell out of it... and If i put my legs between the front wheel i can move the headset slightly... what could be the cause of this!!? |
airfin wrote: DominicLNanni wrote: So i got a new bolt and nut and put it through the headset and tightened the hell out of it... and If i put my legs between the front wheel i can move the headset slightly... what could be the cause of this!!? |
DominicLNanni wrote: the one from the hardware store looked EXACTLY as the one I bought..!!? from ace hardware It might work OK for a while, or it might force you to torque down on it so much that you end up cracking the collar of your headset which wouldn't be recoverable. I'd be heading over to your local scooter shop (or finding someone who has a spare) to get the proper bolt asap. |
![]() 65 Silver Special, 61 Series II,76 Rally 200, 71 Rally 180, 65 ss180, 60 Allstate
Posts: 230 Location: Long Beach, CA |
Yeah your headset bolt should look like this:
![]() If it doesn't chances are someone at some point swapped it out with whatever they had. |
![]() UTC
have had my share of faggy mopeds in my time
Posts: 1286 Location: Surfhenge, CA |
![]() have had my share of faggy mopeds in my time
hp wrote: It might work OK for a while, or it might force you to torque down on it so much that you end up cracking the collar of your headset which wouldn't be recoverable. |
mrmoi2000 wrote: Yeah your headset bolt should look like this: ![]() If it doesn't chances are someone at some point swapped it out with whatever they had. |
Always use the proper bolts. Bolts from hardware stores are not hardened. This could cause big time troubles.
