I finally installed my LED tail lights that Sushiman guided us towards and also installed and wired an LED liscense plate frame with running/brakelights. I also ran a 30 amp, fused, 10 gauge wire from the battery to under the cowl for a future distribution block. I, from that wire, powered the Steibel horn I had purchased some time ago and finally installed.
Nose mount.
Nose mount.
Fits in there perfectly.  I suspended it with that bracket, but it can't fall out.
Had to fix the center light housing.  This is the best I could do.
