I'm new to Vespa and new to the forums... and need a little advice.
I recently purchased a used LX150 that had a Faco front rack installed; the cups have scratched both sides of the legshield to the metal.
I'm trying to piece together information from the (seemingly) hundreds of posts regarding scratch repair and repainting, but haven't found any information or advice on protecting a repainted legshield from further damage if I reinstall the rack. Additionally, I've not had much luck determining if I should use a rattle can or touch-up stick with a repair like this.
So,
1) Assuming I prep and repaint correctly, will the repaired surface be more susceptible to scratching?
2) As the repainted area might have a constant abrasive contact (the rack), is there anything I should do differently in my painting, prep and post?
3) I've ordered both can and touch-up stick, but am still not sure which would be best for a repair like this.
Any suggestions would be greatly appreciated...
