I am vertically challenged. (5'4")
I love the Fuoco, but hate the ride height.
However, I do like the riding position, so I'm not keen on reducing the padding in the seat.
So, I'm thinking shorter shocks. Yes, I know, you also get shorter suspension travel, and you increase the ease with which you scape something on corners.
Well, as far as the travel is concerned, the scoot has 110mm, so there's a bit to play with.
Scraping - On other bikes, when you reduce the shock height, you also make things like the centrestand closer to the ground - so you scrape them more easily. HOWEVER, with the Fuoco, the centrestand (the bit that scapes first) actually moves with the wheel, so it really doesn't matter if you change the shock length. The ONLY thing (I think) that will change the ease of scraping the stand is the size of the rear tyre. Is this why JimC recommends it?
So, two questions:
1. any thoughts on the above reasoning?
2. anyone have suggestions about replacement shocks (say 14-1/2", 360mm long) which have the RIGHT SPRING RATES?
Gonzo.
