regarding the back brakes on my '61/'62 vespa 125cc: the action on the foot peddle is frozen. i've only been able to move it slightly by spraying penetrating oil on it for several days.
should there be some sort of spring making the foot peddle go back to the top position or do the back brake internal springs do that job?
upon very close inspection and using a mirror, i can see a small pin holding the brake peddle in position on the post. does the pin have to be removed in order to release the peddle?
thanks for any help
