@jamesegio avatar
vbb, lx,
@jamesegio avatar
vbb, lx,
topping up the oil today and when unscrewing bolt realized i must have stripped it last time i put it back on. stripped the hole not the bolt.
any ideas on temporary fix?
i'm f'd, right?
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
helicoil? but then you gotta strip the case down as well? i never put one in.
@louispain avatar
Cosa and P200E
@louispain avatar
Cosa and P200E
That stuff the plumbers use. PTFE tape. Wrapped around the bolt thread and screwed back in.
Maybe some instant gasket.
@jamesjohn avatar
@jamesjohn avatar
yea, its not like its under tremendous pressure or anything.
px200
px200
Hello
Seek out a suitable plastic screw.
Grumpy
@jamesegio avatar
vbb, lx,
@jamesegio avatar
vbb, lx,
thanks for the replies. i'll probably try some insta-gasket, since i got some layin' around.
@spunkyantlerdance avatar
64 Allstate 177 71 sprint veloce
Split the case line the hole with about a 16th of an inch of J.B. weld and then lightly tap in new threads. I know it's kinda getto or if you know a welder have him or her put a little meat in the hole then tap it . A welder is you're best way to go .
[ Time: 0.0095s ][ Queries: 3 (0.0015s) ][ live ][ 334 ][ ThingOne ]
