Just looking for some general discussion and to hear other owners experiences here.
Okay, so what do I mean by illusive kick. The kick I am referring to is a little burst of power you can get on acceleration, usually from take off. Basically the engine revs like mad and it feels like the torque sets in to give you a real boost, enough so you feel it and it pulls you back a little. I aint talking screeching wheelies here or anything.
When I bought my bike it ran pretty sluggish (although i didn't know it at the time) When I had a crash and it was written off as a cat c I bought it back as mechanically the bike was okay. My friend who did the repairs also changed the plug for me and put some carb cleaner on and ran some Red X through the fuel system. After this is when I first experienced the kick. The bike would pull pretty rapid up to 30 mph and after that was a much more subtle acceleration.
A year later we gave the carb a proper clean, stripping it down. Some of the jets were clogged with fuel. After this the kick was even better and even the acceleration beyond the 30mph was improved. So I concluded the source of the kick to be a healthy carb.
A few weeks ago my outer variator pulley came loose and was hitting the transmission cover. I simply re tightened the nut (not knowing at the time these were one use only) For a few days the bike ran real nice and quick. Less of an immediate kick but a good strong pull throughout the whole range. Then the outer variator stripped.
I cleaned the crank and replaced the part, the rollers then became very noisy and all kick was gone and acceleration was very sluggish. I figured as these rollers had done 42000km it was time to replace them. I know that's a lot of miles for a set of rollers, but hey, up until then they had been working fine.
I replaced the rollers and belt and the result was staggering. The kick was now present all through the range. At any speed even up to 50+ mph I could give the throttle a twist to WOT and the bike would rev like nuts and pull like a train. I was very happy. Then, boom, the new variator stripped again after a couple of days. What I had done like an idiot is not put the belt far enough into the clutch and it was too tight around the variator. This meant the washer that goes behind the outer variator and touches the spacer was not sitting flush so when tightening the assembly it was not done right. Once the belt went to the top of the variator whilst rising the assembly must have been loose which is what I assume caused the nut to come loose.
Today I bought another outer pulley and did the job (I hope properly) That is to say all washers and spacers were sitting flush. However, now, even with the new rollers and belt I am getting no kick at all. Acceleration is pretty slow, but the pull once above 30 is nice and smooth but nowhere near what it was.
So here's the head scratchers
The carb obviously effects the kick, but to what extent
How come when the variator wasn't fitted correctly the bike performed totally freaking awesome.
I'm thinking because the belt sat lower and rose higher, so effectively changing the cog sizing down? especially setting of from stand still.
If so how come you cant buy a more angled variator that would allow this kind of performance.
Time will tell if once the new belt and rollers settle performance increases.
Sorry for such a long rant but I am very interested to know if other riders get this kick, and more important what is the main factor for it to happen.
Maybe I am chasing something illusive like a leprechaun and his pot of gold but hey, its fun to tinker.
If you made it this far, thanks for reading. And your also probably very bored or very stoned.
dk`
⚠️ Last edited by dk1021 on UTC; edited 1 time
