I need some help! Riding home this afternoon my LX150 started losing power, like a slipping belt and making a sound from the transmission area like a playing card stuck in the spokes. I nursed it home, thinking the belt must be shredded but when I removed the cover there was apparently nothing wrong with the belt, however there was grease sprayed around the inside of the cover and on the pads in the clutch. Also some obvious scraping had worn away areas inside the cover.
I remember reading something a few months ago from someone at MV having a similar problem but can't locate that post now. Any thoughts on what the problem may be? Where might the grease be coming from? I understand that there is grease in the driven pulley, would a failure there cause it to spray about? What to look for?
I plan to clean away the grease as best I can and reassemble tomorrow but I'm guessing that there is a bigger problem.
I will try and attach some pics.
Thanks in advance for you help with this!!
