Lately my GT 200 has not been running well in the hot weather. I decided to do some maintenance; oil change, new spark plug (Denso IU24) and remove that pesky EVAP system. After reviewing the Modern Vespa Wiki I found my system had an extra hose that was not mentioned in the EVAP removal/mod tutorial. My engine has two hoses; one that is described in the tutorial and one that is not. The hose in question is after the carb. With the engine running the "other" port pulls a noticeable vacuum where as the port described in the tutorial has nothing noticeable. The port that pulls a vacuum was covered with a small cloth and a hose clamp. I think both ports need a filter but temporally I left the port on the carb alone until after I hear some suggestions on how to proceed.
Has anyone run into a similar experience? If so; how did you fix it? What did you do with the overflow vent in the neck? I was thinking about plugging the hose off the neck but had concerns about the vapor pressure in the tank in these hot dessert conditions in Albuquerque. Thanks in advance for you help, ideas, and suggestions.
