He said it has been so hot here (over 100 each day for over 2 weeks) that it could just be low of fluid and told me to get DOT 4 to add to reservoir. He pointed me where to go and I went as directed -- SEE PICTURE below, marked with red drawn around it. I added fluid but did not help anything. (In the process I blew a fuse but replaced it.) I have been unable to get the tilt lock to unlock by two rapid right clicks. That just isn't happening so it looks like I'll have to tow it into the shop and God knows when I'll get it fixed.
Does anyone have a suggestion? Anything to try before I have it hauled in? Also, I've never had the bike carried by a carrier. Any suggestions? I hope someone can tell me I did something stupid like putting the fluid in the wrong reservoir but this is the only one I found where he told me it was supposed to be and the top said, "Use only DOT 4 from a sealed container," so I guess it is the right one.
Late edit: SOLUTION can be found at the end.
⚠️ Last edited by jerryw on UTC; edited 1 time
