A buddy of mine is considering this Carburetor " upgrade" from SIP.
Has anybody ever seen this setup installed? I can't quite figure it out.
http://www.sip-scootershop.com/EN/Products/J40112000/Carburetor+kit+28mm+PXT5.aspx
![]() '80 P200E, '76 Primavera 125 ET3. '59 Vespa 150
Posts: 6897 Location: GT, Texas |
Has anybody ever seen this setup installed? I can't quite figure it out. http://www.sip-scootershop.com/EN/Products/J40112000/Carburetor+kit+28mm+PXT5.aspx |
1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
Posts: 609 Location: Atlanta |
I've installed a lot of those. If it not a kitted bike don't bother. What part can't you figure out?
yeah if your bike is a stock 150 the inlet is only 20mm anyway p200 is 24 unless you open it up but on a stock bike that won't do anything
Mattgyver wrote: I've installed a lot of those. If it not a kitted bike don't bother. What part can't you figure out? Myself being only familiar with the usual Vespa Delarto style carb setup, I can't figure exactly how this thing mounts. I'm not installing one. Just curious mostly. Although, this does look more like every other carb in the world, compared to the Delarto, I can't figure how it mounts the vespa. There doesn't seem to be any sort of air filter, that I can see. Does the bellows just go strait from the frame to the carb? is the bellows optional with a filter on? Obviously the oil metering device is history, right. I'm just curious to see an example what it looks like mounted, and what advantage it may offer, other than "more standard type". I'm not interested in any performance upgrades just yet, I'm still learning the stock setup. Like I said, just curious more than anything. |
![]() UTC
have had my share of faggy mopeds in my time
Posts: 1286 Location: Surfhenge, CA |
![]() have had my share of faggy mopeds in my time
astromags wrote: I'm just curious to see an example what it looks like mounted, and what advantage it may offer, other than "more standard type". I'm not interested in any performance upgrades just yet, I'm still learning the stock setup. Like I said, just curious more than anything. The 1/4 pipe thing sits over top of the reed block. The small donut black piece connects that part to one side of the carb, then the carb, then the bellows runs to the normal frame hole in the scooter. There is no filter. |
It looks like this but instead of a filter on the carb, the rubber bellow goes there and attaches to the body. The one your friend is looking at is NOT the reed valve one.
http://picasaweb.google.com/lh/photo/Ktow0JRP5g1z52vCCydA0g |
![]() UTC
Mattgyver wrote: The one your friend is looking at is NOT the reed valve one. |
Mattgyver wrote: It looks like this but instead of a filter on the carb, the rubber bellow goes there and attaches to the body. The one your friend is looking at is NOT the reed valve one. http://picasaweb.google.com/lh/photo/Ktow0JRP5g1z52vCCydA0g Obviously a setup for the guys who like to crack the cases on a regular basis. |
![]() UTC
astromags wrote: Obviously a setup for the guys who like to crack the cases on a regular basis. never had any issues associated with it other than cleaning up some blow-back from time to time. |
RIP
![]() T5s
Posts: 17005 Location: The West Of Yorkshire ... Gods Country |
chili scrotum balm
ive got 2 dellorto carbs with all the fixing kit ... one has a pump ..... just need time to fit the bugger .....
then i can sell the other off |
i was using a filter for a awile but it chokes out my rich ass carb. it runs like a top filterless and ive got over 1500 miles on it since i installed the carb and the only thing i had to crack the cases for were gear related. before i had this setup i had a 24/24 with no filter. never had a problem i guess if i rode around on the beach it might be a problem but ive never swallowed anything in my carb mouth.
