Hi all, Just seeking a bit of advise. I am installing heated grips (Symtec under grip wraps) in my Gt and the instructions suggest tapping in to an active power source such as the headlight (optional fuse) . Others here at MV have suggested wiring directly to the battery. Concerns are that there might not be enough power for both the heated grips and headlight with the tap option or that direct wiring could allow the grips to be turned on and drain the battery while the scooter is parked. Not sure if this matters (I am a total electrical newbie) I have already installed an audible turn indicator using the alarm harness and think this will limit the switched power options.
As an aside I also installed LED Brake lights (currently brake light only) in the top case backed by SOLAS tape. I just took delivery of a dual element circuit (thanks baca008) and was going to run them as both running and brake lights (with a BackoffXP modulator) but some of our club members have suggested that the way it is now really has impact when the brakes are lit up and the addition of the running light function could water the effect down.... time to experiment and solicit opinions I guess . I will post a project report soon.
AND a HUGE Thanks to all MV members for the great info here... I am not at all handy and with the information here have totally surprised myself (and my wife)
Cheers
Mike
