For those with battery tenders: Can you plug it in from outside the bike or do you take the 4 screws out and remove the plastic black plate in the floor every time? How is it mounted?
thanks in advance
I bolted the battery tender cable to my battery, but there does not seem to be anyway to enable easy access to it from outside the black plastic panel. I really don't want to drill any holes, because it only invites water
For those with battery tenders: Can you plug it in from outside the bike or do you take the 4 screws out and remove the plastic black plate in the floor every time? How is it mounted? thanks in advance ![]() |
You should be able to run it towards the back. From either side of the scooter (while you are on the ground), look towards the front from the back of the scooter. You will see wires and stuff running into the floor board area.
![]() '12 Kymco People GTi300, '06 Yamaha Morphous,'10 Vespa GTS300s
Posts: 380 Location: las cruces, nm |
Battery Tender
I ran mine back thru the engine compartment and thru the pet carrier on one side (it makes no difference which side). I then cut an opening thru the pet carrier near the bottom and pulled the plug-in thru, and then I just plug the Battery Tender in and close the seat. There's room for it to fit easily. The only problem I've found with this is during service or any reason for taking the pet carrier out...you must work the pig tail thru before removing it.
karlu las cruces,nm |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 44693 Location: Pleasant Hill, CA |
There is just room to either get it very readily available at the front of the underside of the seat (there are holes in the metal for this), or you can just leave it in front hidden by the pet carrier.
The Beer Guy
![]() 2010 GTS 300 Super and 2015 Kawasaki Versys 650 LT
Posts: 4744 Location: Nelson County, VA |
I ran mine underneath and used cable ties to attach it to the other cables that are there. I have mine on the left side poking out just behind the floorboards.
jimc wrote: There is just room to either get it very readily available at the front of the underside of the seat (there are holes in the metal for this), or you can just leave it in front hidden by the pet carrier. |
![]() Looking for the next one, probably electric
Posts: 3695 Location: Babcock Ranch, Florida |
I ran mine back into the engine compartment and used wire ties to secure it there. I have to remove the pet carrier to hook up, but that's OK because I don't do it often. If you run it under the edge of the pet carrier or through an unprotected hole in the body you run the risk of fraying through the insulation. Most of them have a fuse that would protect the wiring, but there are scenarios where the wear could be close to the battery and that would drain the battery, or start a fire,
By the way, I wrapped some white electrical tape around the black connector to aid me in finding it in the engine compartment where everything else is also black. |
![]() UTC
GRAPHITE LX 150
Posts: 762 Location: delaware, Bethany Beach |
I have a lx 150, so it may be different, after attaching cable thread it through letf of two holes in battery holder, continue to left over air filter (i think) inside cowl where it hangs over variator above dip-stick, the tender stays in the glove box. Damn, my life is complicated.
jimmythehat wrote: I have a lx 150, so it may be different, after attaching cable thread it through letf of two holes in battery holder, continue to left over air filter (i think) inside cowl where it hangs over variator above dip-stick, the tender stays in the glove box. Damn, my life is complicated. |
I had wired, directly to the battery, a 12v socket (cigarette lighter type) to the knee pad on my ET4 in order to plug in my iPhone or GPS. Turns out it's perfect for using an adapter and plugging in the charger to charge the battery.
![]() UTC
GRAPHITE LX 150
M2DB
I don't have pics or pic know hosw. But i think I recieved the info from Danny from Texas has a picture of a penguin dunking another - someone on here will know how to find him!
Re: M2DB
jimmythehat wrote: I don't have pics or pic know hosw. But i think I recieved the info from Danny from Texas has a picture of a penguin dunking another - someone on here will know how to find him! |
![]() UTC
Posts: 4332 Location: Utah Valley |
RIP
![]() 29,000 miles on my atlantic pastel green 2007 GTS 250
I have heard of some members who run their connector behind one of the foot pegs. When they need to hook up the tender, they fold out the foot peg and pull out the plug behind it. When done, they stuff the plug back in and are done.
I ran mine into the engine bay and access it after taking out the pet carrier. BTW, this is what I did with the extra cable: I cut off the crocodile clamps and soldered the ends to a cigarette lighter socket. Now I can charge a phone or something by just plugging this into the pigtail connected to the battery. ![]() ⚠️ Last edited by windbreaker on UTC; edited 1 time
![]() Vespa GTS 300 Super & Vespa P125X
Posts: 4134 Location: St. Petersburg Florida |
Run it up under the pet carrier and zip tie it to the side somewhere. When you go to charge it just pop the seat and take the pet carrier out.
![]() UTC
GRAPHITE LX 150
![]() UTC
RIP
jimmythehat wrote: Windbreaker great idea -- do I need to know which wire goes where ? |
![]() UTC
GRAPHITE LX 150
M2DB & WB
M2 If you click on this Where's the mod for easy batter tending? the last response will be Danny*h with appropriate pics, other solutions are there as well. UtahValley thanks again just got the drift of WindBreaker, Got a Chuckle! OZIO "The Art of Doing Nothing"
Re: M2DB & WB
jimmythehat wrote: M2 If you click on this Where's the mod for easy batter tending? the last response will be Danny*h with appropriate pics, other solutions are there as well. |
Yay! I did it! I went to my local vespa dealer and got the BT jr and installed it. Thanks for the tips.
Michael Bruening Smiles Distributors 414.803.9255 ![]() |
