So its 95 degrees in the shade today again but the sun went away for a bit so I decided to try and finish putting this damn bike together. Got it 95% back together. I installed the seat and went to close it......nothing, it won't latch shut.
I played around with it for a while. When I pressed the electric button you could hear the motor kick on but the latch wouldn't move. It was staying open. I took a screwdriver and tried to manually close the latch. It moved but not much. I was already outside working on the bike for a few hours and the sun came out and I was literally dripping with sweat.
I popped the glove-box door to grab the manual release lever and to my wonderful surprise I found the lever jammed open. Apparently when I put the glove-box and leg-shield together I somehow managed to allow the cable housing to slip back into the back of the box and now it was F$%king everything up. Look at the picture below. since I had to go to dinner I rolled the bike back into the garage disgusted.
I would rather crawl through a field of broken glass than take the leg-shield assembly off again. I am wondering if I can get the cable back through into the glove-box again with a tiny screwdriver and a small pair of needle-nose pliers. That or I may drill a small access hole next to it and try to pull it through that way. I was not up to messing around with it anymore today so I didn't really spend too much time looking at it.
AAHHHHH !
