@fwoiii avatar
2010 GTV250ie
@fwoiii avatar
2010 GTV250ie
Is there an adjustment for the fender mounted headlight left to right?
@miguel avatar
@miguel avatar
I don't know the answer to that but it might be obvious if you were to take the light out. Procedure for that is here.
If you find it, let us know.
Best
Miguel
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
Not as far as I'm aware. The adjustment screw that's up underneath it only moves it up and down. Any adjustment side-to-side would have to be made with the headlight off (out of the cone), and really just by bending the mounts, so it would be a real pain to actually do.
@fwoiii avatar
2010 GTV250ie
@fwoiii avatar
2010 GTV250ie
Thank you very much.
@marktheblue avatar
GTV125 & GT60
Location: England, somewhere down in the bottom left bit...
@marktheblue avatar
GTV125 & GT60
Tinker
...or possibly using washers between the reflector and metal bracket which bolts to the back of it to change sideways alignment...?
Best,
Marky
@superblackbox avatar
GTV + ST11
GTV + ST11
Re: GTV headlight
dnt mind i ask. why would you want to adjust ??normally its adjusting higher or lower.....
[ Time: 0.0104s ][ Queries: 3 (0.0027s) ][ live ][ 313 ][ ThingOne ]
