Hi all , I purchased a sidestand for my 2007 Vespa 250 IE , could use some help with install or demo pics of install. Spent time looking on the search fuction , could find any instructions
The Beer Guy
![]() 2010 GTS 300 Super and 2015 Kawasaki Versys 650 LT
Posts: 4744 Location: Nelson County, VA |
I just installed one on my GTV a few days ago that I got from Scooterwest.
Go here: http://tinyurl.com/27odnd8 and click on the 'More Information' tab on the page. It provides step-by-step instructions. The photos aren't the clearest, but good enough. If you have any specific questions feel free to PM me. |
![]() UTC
Posts: 2379 Location: Chicago, IL |
![]() 2009 GTV 244, 2005 BMW F652 CS, 2001 ET4 150
A couple of notes:
1. make sure you pack it well with grease. 2. make sure you seat the o rings properly. |
![]() 2009 GTV250 (Gone), 2003 Inder trailer (also gone), 2001 BMW R1100RT
Posts: 5707 Location: Santa Cruz California |
stinkyjones wrote: A couple of notes: 1. make sure you pack it well with grease. 2. make sure you seat the o rings properly. Best Miguel |
Can't get the more info button to work
Can't get the more info button to work on scooterwest , trying for hours, any other areas i might find install info instructions or pics or you tube
Re: Can't get the more info button to work
scootergil wrote: Can't get the more info button to work on scooterwest , trying for hours, any other areas i might find install info instructions or pics or you tube Best Miguel |
![]() UTC
What browser are you using?
No problems with FF 3.6.8 on Mac. To my knowledge, those are the only online instructions . . . everybody here uses them for the install. [edited for gawd-awful grammar] ⚠️ Last edited by stinkyjones on UTC; edited 1 time
stinkyjones wrote: What browser are you using? No problems with FF 3.6.8 on Mac. To my knowledge, those are the only place I've seen the instructions . . . everybody here uses them for the install. Best Miguel |
Install instructions i.e more info on sw site
I finally was able to access the Sidestand install Instructions by going to the print function and was allowed access to view ... Whew thanks to all for the helpful post info.
ET2, ET4, in Mexico GTS-250 in Ca
Posts: 173 Location: Puerto Vallarta, Mx Los Altos, Ca |
Just put one on my 250 GTS. The difficult part is putting the O rings on the stand. When you look at the stand, the O rings slip over the two arms that the mounting bolts goes through. That is, they pull down all the way. Then put the bolt through and after you tighten it slip the outside part of the O ring up and over and you have a seal on the bolt. Supposed to keep water, etc, out of the joint. Someone also suggested that you can use a cable tie, put a loop in it, and use that to pull the springs to install. It worked for me.
