I am in a bit of a conundrum. The fork that originally came on my '64 Allstate has been cut and welded back together (bottom right). To fix it, the folks at Motorsport Scooters sent me a replacement off an Allstate they scrapped. My problem is that the forks are not the same. If you look at the picture, the replacement fork (cleaned up) is longer than the one that came on the '64 scoot.
Looking at the two of them side by side, I've notice that the threading is in different locations at the top and the pivot is likewise displaced at the bottom.
Will the replacement fork work or do I need to go after another one? Is there a way to tell which one belongs with the scooter? There is some stamping on the neck but I don't know if that indicates anything useful.
Thanks in advance for the replies. This is a tough question with an answer I suspect will only come from dry fitting parts before painting.
Justin
⚠️ Last edited by jlreis28 on UTC; edited 1 time
