The clear tube which leads to the Fuel Tap (i think that is what it is), had a small slit in it a few weeks ago. I noticed this when I was stopped at a red light and the stench of gasoline filled the air. Strapped for cash, I did a little quick fix by applying some tape tightly around the tube which helped for a week or so.
Since then I have had to redo it a few times because the gasoline eats away at all the stickyness and I usually end up getting stuck in a parking lot when this happens and have to fix it again.
So my question is, where can I find a tube the same size so I can replace it and fix the problem for good?
I was thinking Home Depot maybe, and taking in the tube and asking an employee to help me find the right size. However, i'm not sure they will have the correct size.
Here is a photo, you can see where I have it taped.
Thanks for any advice!
Tony[/img]
