Silver Streak wrote:
The wording of the original post is extremely awkward and confusing.
After reading it several times, I gather that the OP's husband tried to start the scooter from the Lexus using permanently installed Battery Tender leads on the scooter battery to make the connection from the jumper cables (the original post makes it sound as though he tried to use the Battery Tender charger on the Lexus!). Trying to jump start the scooter via the Battery Tender leads will, of course, blow the fuse in the lead as the starting current far exceeds 7 amps.
Jump starting a scooter from any car is no problem, as long as you connect the jumper cables directly to the scooter battery (which, of course involves removing the battery cover, which is probably the hassle the OP's husband was trying to avoid). No need to have the car engine running, and it is probably safer for the electronics all around if it isn't.
We'll probably get clarification from the OP
after the garage fire has been put out.
SDG
