BubbaJon wrote:
norCal Randy wrote:
StooterBoy wrote:
norCal Randy wrote:
I'm using Wal-Mart 10W-40 auto dino oil and have used this kind of oil all my bike riding life(47 yrs.). Will let you know if I ever regret it.
I have a `91 VX800 Suzuki that's had this kind of oil in it since new and at 84K miles have had NO motor/clutch/tranny issues whatsoever. But I do change my oil more often than recommended.
5W-30 and 10W-30 are the oils that are supposesd to be too slippery for wet clutches like 2 of my bikes have. I only use these viscosities in my car & truck.
I use no synthetic oils in anything.
To each there own, Piaggio doesn't
require synthetic for no reason.
JASO MA is comparable to our SAE recommendations in Japan. 5W is only needed if you operate your vehicle in 20 below temps. I don't do that, do you ? Piaggio recommends Agip City Hi Tec 4T oil, made for 4 stroke engines. What I use is made for 4 stroke engines but is also OK for turbochargers. I don't see my motor oil getting as hot as a turbocharger can make it.
I also have a `04 air cooled MC that says to use 5W-40 oil, It now has 37K miles and I use 10W-40 dino oil in it just like the MP3 with no worries so far.
I was just pointing out that "slippery" was incorrectly used in context with viscosity - they are not the same. Turbocharged engines use an oil intercooler if they are designed for oil cooling - the temp will not exceed the oil ratings just because the engine has a turbo. 5W spec has little to do with temperature. The multi weight oils are blended to provide engine protection during that all important start up when cold - i.e. not at operating temperature. The low viscosity ensures that the oil will not shear and leave metal unprotected. Finally:
JASO
The Japanese Automotive Standards Organization (JASO) has created their own set of performance and quality standards for petrol engines of Japanese origin.
For 4-stroke gasoline engines, the JASO T904 standard is used, and is particularly relevant to motorcycle engines. The JASO T904-MA and MA2 standards are designed to distinguish oils that are approved for wet clutch use, and the JASO T904-MB standard is not suitable for wet clutch use.
For 2-stroke gasoline engines, the JASO M345 (FA, FB, FC) standard is used, and this refers particularly to low ash, lubricity, detergency, low smoke and exhaust blocking.
These standards, especially JASO-MA and JASO-FC, are designed to address oil-requirement issues not addressed by the API service categories
So JASO is loosely an equivalent to SAE in that they are an automotive standards organization but they have different and unique specs to fine tune requirements. If SAE specs did the job I can assure you there would be far fewer letters on your oil...
"5W spec has little to do with temperature". I totally disagree. The thickness(flow rate) of most oils is directly proportional to the ambient temp. of the oil before startup. Thinner weight oils are for colder temps. mainly. Multi weight oils automatically adjust the flow rate according to the temp. they are active in. Where I live/ride, 10W oil is more than enough to handle high 20sF in the coldest time of the year here. I'm more concerned with the high ambient temps than the low temps. Besides, a water cooled motor has far less high temps to deal with.
1/2 my rigs are air cooled motors. That's why I run 10W/40 in the winter and 20W/50 in the summer(triple digits) for them.
A manufacturer recommended oil viscosity has to do with all possible conditions they can think of where a customer might be using their vehicle. Whereas I'm only concerned with the temps. I will ever be in when riding. Therefore I reject all the absolutes the factory recommends for.
My Italian `81 MC's factory recommended dino 10W-50 oil not even available then in the USA when the bike was new. Accordingly I used 10W-40 in the winter and 20W-50 in the summer. That was over 100K miles ago. I know an owner that has ridden his same motor for over 300K miles now the same way as me.
