scootr74 wrote:
I have replaced my Fly 150 rollers with different weight ones along with a belt change.
My question is do new rollers and belts have a break-in period? I seem now to have less power than I did before.
Any ideas?
You can't just arbitrarily change the weight of your rollers -- without knowing exactly what you are doing and why -- and not have the likelihood or either loss of acceleration or top speed. With some experimentation with subtle weight changes (half a gram less or so), you may be able to get a small improvement in acceleration without sacrificing top speed, particularly if you are heavier than average, but "shot-in-the-dark" changes in weights are more likely than not to have negative consequences.
Also, if the new weights are not precisely the same size, your performance will definitely suffer.
