![]() UTC
GT 300 Super Sport
Posts: 72 Location: Rockport, Texas |
I had a small Faco windscreen installed on my 250 about three weeks ago. Tonight was the first time I took it out after dark. The bottom of the windscreen picked up the light and distributed it throughout the windscreen like a fiber optic light. I was looking at a very bright light shining in my face. No way I could drive like that. The bottom of the screen is just in front of the top of the headlight. In other words, the bottom of the screen is about one-half inch out from the light, and about one inch below the top edge of the headlight. Was the windscreen installed improperly, and if so, how can I adjust it?
Resident Gentleman
![]() --------2008 LX150-------- Sold
Posts: 5045 Location: Brady, TX |
Try one of these:
![]() $24 from here: http://www.jettin.com/Visor.htm I have one on my LX150 and love it. |
![]() UTC
GT 300 Super Sport
danny*h wrote: Try one of these: ![]() $24 from here: http://www.jettin.com/Visor.htm I have one on my LX150 and love it. Thanx much, Greg |
Re: Blinding Windscreen
Grantwriter wrote: ..., the bottom of the screen is about one-half inch out from the light, and about one inch below the top edge of the headlight. Was the windscreen installed improperly, and if so, how can I adjust it? |
![]() UTC
Posts: 8758 Location: Annapolis, MD, USA |
![]() 2007 Vespa LX 190, 2011 LXV150ie
You might want to try loosening the expansion bolt nuts (the 17mm nuts where the brackets go into the tubes on the headset) to see if the windscreen can be pushed farther in. With my small OEM Vespa flyscreen on my LX, the screen sits far enough back that it doesn't transmit significant light.
Silver Streak wrote: With my small OEM Vespa flyscreen on my LX, the screen sits far enough back that it doesn't transmit significant light. ![]() |
Resident Gentleman
My cut-down tall Vespa windscreen didn't transmit much light either, but I didn't know about the Faco.
However, the Jettin visor does look cool. And I don't even see the lit up top of the headlight, let alone any transmitted light. |
![]() UTC
GTS 300ie
Posts: 1731 Location: Sunshine Coast, Australia |
you just need some electrical tape accross the top of the head-light - a visor looks cool but will slow you down !!
![]() 2007 LX190 RIP 1980 Honda CM400T SOLD 2013 Shadow 750 RIP
Posts: 1496 Location: Crofton,MD |
Goto the AutoParts store and get a strip of door edge molding.
Cut it to fit and slide it onto the screen above the headlight. |
![]() Looking for the next one, probably electric
Posts: 3697 Location: Babcock Ranch, Florida |
got mine wrote: Goto the AutoParts store and get a strip of door edge molding. Cut it to fit and slide it onto the screen above the headlight. This works fine. Been there, done it. Even looks pretty professional. |
![]() UTC
MV Santa
Posts: 4921 Location: Sedgwick, Kansas |
MV Santa
![]() GTS250, 1975 VBC, 1980 P200E cutdown, GT200L
I have a full size Faco. The bottom edge on mine is 1/2 inch above and 1/2 inch behind the top edge of the headlight. At night the entire edge of the screen glows like fiber-optic but it's not so bright as to be distracting. Is the shield mounted as high on the uprights as possible?
![]() UTC
GT 300 Super Sport
Jettin Visor
I bought the Jettin Visor as Danny suggested, installed it, and totally solved the problem. And it looks good with the windscreen also. This is a truly great forum. Thanx to all for your suggestions.
The Beer Guy
![]() 2010 GTS 300 Super and 2015 Kawasaki Versys 650 LT
Posts: 4744 Location: Nelson County, VA |
Looks very nice. This is sort of like the Stump the Chumps segment on Car Talk when they bring an old caller in to see if the problem was solved with the advice that was given.
