i saw a gts 250..looked nice in the ad...but found it was not a ie
I think the ie is fuel injection. and i was wondering if it made enough of a difference for me to keep looking for the 250ie gtsie or gtvie
thank you
2007 250 GTS ie
Posts: 105 Location: Florida and Long Island NY. (Motorhome) |
I think the ie is fuel injection. and i was wondering if it made enough of a difference for me to keep looking for the 250ie gtsie or gtvie thank you |
There is only one model and both terms are used to describe the GTS 250cc fuel injected model.
![]() GTS 300ABS, Buddy 125, Buddy Kick 125
Posts: 13524 Location: Oregon City, OR |
![]() UTC
Beer Fairy
GTS-"Cannonball Bettie" Member Iron Butt Association
Posts: 851 Location: Seacoast New Hampshire USA |
Beer Fairy
![]() GTS-"Cannonball Bettie" Member Iron Butt Association
2007 250 GTS ie
confused re ie or no ie
It is good to hear that all gts and gtv 250 of all years are fuel injected. I wrote to a person that had advertised a gts 250...i asked if it was an ie and she said no. I thought ie meant fuel injection....if not....are there models that are not ie and if so what is the difference? thank you
Re: confused re ie or no ie
iAmGadget wrote: It is good to hear that all gts and gtv 250 of all years are fuel injected. I wrote to a person that had advertised a gts 250...i asked if it was an ie and she said no. I thought ie meant fuel injection....if not....are there models that are not ie and if so what is the difference? thank you Yes, ie means fuel injection. Also, in common discussion "ie" is rarely affixed to the name. The only people who refer to it as "250ie" are people who just bought their scooter. |
iAmGadget wrote: It is good to hear that all gts and gtv 250 of all years are fuel injected. I wrote to a person that had advertised a gts 250...i asked if it was an ie and she said no. I thought ie meant fuel injection....if not....are there models that are not ie and if so what is the difference? thank you |
2007 250 GTS ie
thank you...now i have to find one near me
I love when there is no doubt. thank you all for clearing this up.
I just sold my last motorcycle. bought a coach ( motorhome ) and want to put something smaller than the large bike on the rear of the motorhome. I just received a Versahaul with ramp. I am on Eastern Long Island NY until nov...then i go back to Florida. I figured a used 250 would work. I am concerned about the small wheels...but then i read about riders that took their vespa long distances and i like to hear that. I will search here on long island and parts of Connecticut ( ferry across the water) and if i cannot...then i am certain i will find something when i return to florida. As i look i do see other brands that look good too....but the Vespa charisma has a bit of a hold on me.....although i never rode one. thank you all again for your comforting information.... Ride safe.....and enjoy |
Yes all vespa 250s are IE engines, only a few select machines got the piaggio quasar 250 engine with a carb....
The bit that confuses a lot of people is a piaggio with EFI marked on it, means its carb'd... but with EFI technologys ignition Bloody italians trying to confuse us. ![]() |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 44785 Location: Pleasant Hill, CA |
Yep - the new GT200 CDI was marked EFI - which I think is just the manufacturer. And that is definitely carb'd.
![]() UTC
MV Santa
Posts: 4919 Location: Sedgwick, Kansas |
MV Santa
![]() GTS250, 1975 VBC, 1980 P200E cutdown, GT200L
One other thing: GTS's might be heavier than you think. With the Versahauler and other incidentals you will be aproaching 500lbs. Make sure your hitch can havhle that much toung weight. Also search "Canyon Dancer".
jimc wrote: Yep - the new GT200 CDI was marked EFI - which I think is just the manufacturer. And that is definitely carb'd. |
2007 250 GTS ie
oh oh few select models?
cheekythomas wrote: Yes all vespa 250s are IE engines, only a few select machines got the piaggio quasar 250 engine with a carb.... The bit that confuses a lot of people is a piaggio with EFI marked on it, means its carb'd... but with EFI technologys ignition Bloody italians trying to confuse us. ![]() |
2007 250 GTS ie
vintage red matthew wrote: One other thing: GTS's might be heavier than you think. With the Versahauler and other incidentals you will be aproaching 500lbs. Make sure your hitch can havhle that much toung weight. Also search "Canyon Dancer". i will look closer at them...but the Versahaul is set up with the tie down points closer to the inside of the handle bars. it usually is not good for the bike to be tied toward the handle bar ends. I use straps and then the hook through the strap. I have never tied a scooter so i need to take a closer look at best place to tie down. also the motorhome that the versahaul will be on can handle way more weight. It is a diesel pusher. You can put a hydraulic life and a full size dresser/cruising bike on it without worrying about the weight ( again...that is on a diesel pusher ) thanks for the info...greatly appreciated |
Piaggio has used a carburetted 250 in other scooters namely the BV and the Derbi GP1. All Vespa GTS 250s are fuel injected, no matter what the (ignorant) owner is telling you.
Moderibbit
![]() 1980 P200E - "Old Rusty", 1976 ET3 Primavera
Posts: 8891 Location: Atlanta, GA |
Re: oh oh few select models?
iAmGadget wrote: thanks...but now you got this perfectionist concerned again....When i called this person and asked if her GTS was ie or fuel injection and she said no. How do i know she is wrong? the scooter is a distance away from me so i am not going to take a very long ride. thanks Second of all, the seller WAS wrong. There is no question. They are just an idiot. Tons of people buy fancy things and don't know what makes them tick. If this person is selling a GTS (any model: 250, 300, Super, whatever) it IS "i.e." Don't sweat it. We have people on here who know more about these machines than many mechanics do. A GTS is a fuel injected scooter, and as fast and efficient as you could want out of a machine of that size You'll love its nimble handling relative to larger-wheeled MCs. Welcome to the site! ⚠️ Last edited by xantufrog on UTC; edited 1 time
As others have said GTS/GTV are all "ie".
I know you said you're on Eastern LI and Northvale NJ ins't exactly close, but Alan at Metro Scooter has a bunch of quality used GTS/GTVs. He's a great guy and actually delivers to NYC for free. http://www.metroscooter.us/inventory/Inventory.html |
2007 250 GTS ie
thanks everyone
i thank everyone....this is a great site...and i am close to getting my Vespa. if all goes well i will have it this week.
re ie and fuel injected 250's. According to Piaggio HQ. Not all 250's are fuel injected. If it was purchased from a dealer in this country it should be. If it was brought from Italy it might not be fuel injected... So...best way...get the VIN # and Call Piaggio. that is the info i got from the people at Piaggio in new york HQ. There is always a surprise somewhere. After i get it...i most likely will want some accessories. I want rear crash bars and maybe a front luggage rack ( it comes with the vespa trunk and rest pad. i might want a side stand it also comes with a windshield not sure which one..i believe it is a vespa...next size up from the real small one. Now i have to find out about the after market...since i hear that some products are better than vespa.... i hope to get good feedback from all of you.... and thank you all for being there....take care...good luck and ride safe |
Re: thanks everyone
iAmGadget wrote: According to Piaggio HQ. Not all 250's are fuel injected. If it was purchased from a dealer in this country it should be. If it was brought from Italy it might not be fuel injected... So...best way...get the VIN # and Call Piaggio. As others have stated, there are a handful of non fuel injected 250 Piaggio scooters in the US. But absolutely none of them are Vespas. If the Vespa is a 250, and it's in the US, it's fuel injected. End of story. Regardless of what a clueless seller may try to tell you. Piaggio is the parent company of Vespa, and releases scooters under both the Piaggio and the Vespa names. |
![]() UTC
A fracking cage sadly
Posts: 4000 Location: Seattle |
Re: thanks everyone
Witch wrote: As others have stated, there are a handful of non fuel injected 250 Piaggio scooters in the US. But absolutely none of them are Vespas. |
IamGadget: I don't understand why you keep beating this dead horse. You're either trolling and screwing with us or you're refusing to understand. You have been told repeatedly that if it's a Vespa and it's a 250 then it's fuel injected. But, for some reason, you keep asking the same question. This forum has a zillion members and not one person has told you that there are any Vespa scooters with the 250 engine that are not fuel injected.
**One more time: If you buy a Piaggio BV250. some were carbed BUT ALL Vespa GTS models (which were the only ones with the 250cc engine) are fuel injected. The people that I dealt with on another issue who work for Piaggio/Vespa in New York didn't know squat about the products that they sell. This forum is full of good knowledge so either accept it or please quit asking the same damned question and getting the same answer .............and attempting to prove us wrong. Thank you in advance for your cooperation. |
Re: thanks everyone
iAmGadget wrote: that is the info i got from the people at Piaggio in new york HQ. |
