Piaggio mp3 500
Piaggio mp3 500
Re: MP3 500
[I just had a used MP# 500 delivered. The right front turn signal bulb case is disconnected from the rubber coated arm. Do you know to reattach the light to the arm?
Hoyt
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
Pull the lens off and you can slip the housing back on the stalk.
@rjeffb avatar
Bracketmeister
Bracketmeister Emeritus (retired)
Bracketmeister
@rjeffb avatar
Re: MP3 # 500
hwalbridge wrote:
Re: MP3 500
Hoyt
Yes - by doing a search on the subject, by which you will find that this answer has been asked and answered many times on this forum.
@yayadave avatar
MP3 500 - GTV250
@yayadave avatar
MP3 500 - GTV250
hwalbridge
You don't want to literally pull it off. Use a screwdriver. When you have it apart, you'll be able to see how it has to go back together with a minimal amount of dexterity. (Means even I can do it!!)
If you find this irksome, just remember that this way you don't have to buy a new one every time you bump something or something/someone bumps your light.
after you remove the lens cover you will see a horseshoe typ clip . pull this out and slip the turn signal back into the socket part , then push that slip back in the groove and reinstall the cover. if you need any pics or anything to help out let us know.
[ Time: 0.0150s ][ Queries: 3 (0.0051s) ][ live ][ 329 ][ ThingOne ]
