@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
I figured I may as well remove the evap and roll over. Posting this mainly so I can link to them for a wiki I will do on this.
⚠️ Last edited by stickyfrog on UTC; edited 1 time
@bikemor avatar
2009 MP3 500, Red. Had MP3 250, Barron 150 Retro
@bikemor avatar
so why??
I have the 250. Why would you do this?
What is that thing under the seat?
I've had mine a part like that once. Pretty easy.
Just wonder why do it?
Great pics.
@bubbajon avatar
RIP: MP3 500 - Brutto Moto
@bubbajon avatar
The evap canister is a known culprit for stalling out and other oddball issues... on all models I might add.
@rjeffb avatar
Bracketmeister
Bracketmeister Emeritus (retired)
Bracketmeister
@rjeffb avatar
Fuzzy EDIT: (I meant Sticky, dammit I hate when I do that), the can and its bracket look identical to the one in the 500. If so, that bracket just happens to exactly fit the mini air compressors that have been posted about.
Just sayin'.
⚠️ Last edited by rjeffb on UTC; edited 1 time
@fuzzy avatar
@fuzzy avatar
rjeffb wrote:
Fuzzy, the can and its bracket look identical to the one in the 500. If so, that bracket just happens to exactly fit the mini air compressors that have been posted about.
Just sayin'.
My bracket went in the trash a year ago. No regrets.
Sticky, pay attention to where the vent line ends up. A full gas tank on a hot day (not that those happen often in Florida ) will push some gas through the tube. Don't want it venting around hot exhaust. On one occasion after over filling my gas tank I had some gas hitting the ground before I finished getting my gear back on to leave. The vent hose still goed up just under the seat bucket so the gas was pushed up and over. Also with a filter on the vent line, will it still work when it becomes saturated with gas?
If this subject is new to others, be advised that only North American Piaggios have the evap canisters and roll over valve installed. Others just have an unfiltered, open vent line on the gas tank. Many here and on general forum have reported solving problems by eliminating the canister. If your gas tank is under pressure or vacumn when you remove the gas cap then you have a cloged canister and or malfunctioning roll over valve. One member reported enough pressure that when unscrewing the cap it blew off past his head and over to the next pump.
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Bikemor
The black thing under the seat is a charcoal, evaporative canister and is there to take gas vapor vented from the fuel tank and send it to the intake to be burned when the engine is running or vent it after it goes through the charcoal thus keeping it out of the environment. Or at least that is my basic understanding.
There are a few reasons to get rid of it.
1. The bike was designed without this system and it is only added to US models because of environmental laws in California. Some feel that it can have negative effect on performance of the engine and many times it is the first system disconnected when troubleshooting to rule it out.
2. Increases under seat storage area.
3. It has been reported that overfills of the gas tank can cause issues with evap canister (though I don't quite understand how the gas gets past the rollover valve) and the canister causes stalling and rough idling issues. This has also been reported in some scooters that have been tipped over.
4. In my experience the system (i think mostly the rollover valve) causes a negative pressure in gas tank. Some report positive pressure. From what I understand there is supposed to be zero pressure.
So I figured since I have the side panel off to fix my voltage regulator I may as well get rid of the evap system.
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Just sayin'.
I was also thinking extra fuel, fire extinguisher, water of maybe even a can of fix a flat.
Fuzzy
I put the vent line forward of the exhaust pipe so it should be safe. Not sure about the inline filter performance if it gets soaked with gas. I will be watching it and will report if it causes a problem. I am thinking that I may use this as a feed from an aux tank maybe from the pet carrier or somewhere. I would need to figure out a new way to vent.
@bravotwofour avatar
'09 Mp3-500 - Gone Now
stickyfrog wrote:
Just sayin'.
I was also thinking extra fuel, fire extinguisher, water of maybe even a can of fix a flat....
Nice series of photos, sticky. Will be great in the wiki.
Actually the bracket on the 500 is very different - but the concept is the same using that bracket to support something of ~real~ value in the per carrier makes a lot of sense! The bracket on the 250 looks to mount in square and level, as opposed to the oddball angle on the 500. Pic below.
Link to my thread on air compressor install using evap canister bracket.
Evap Can Bracket in Mp3 500 Pet Carrier
@hollybry avatar
2007 Piaggio MP3 250 (sold) and 2009 MP3 400 (sold) 2011 CanAm Spyder RSS
@hollybry avatar
Question - if you remove the rollover valve, what would keep the scoot from leaking gas in the event of a rollover? Not that I plan on rolling over any time soon....
Just a note - a hot exhaust won't make petrol liquid or vapour ignite - it's not nearly hot enough! It'll just boil or dissipate. Zero problem.
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Yeah I wasn't as worried about gas on the exhaust as much as keeping it off the tupperware or and other parts that may not like it.
Holly. No not too worried about gas escaping if the bike goes over. I believe roll over valves are put in to keep the charcoal in the cannister safe. Laughing emoticon
Seriously though I don't think much spillage occurs so it really doesn't worry me much. I have and bikes going back to the 70's that I have dropped and the only gas issue I can remember is flooded carbs.
me thinks a small flask of whiskey will strap right in the old evap can spot. very important when going camping having the proper fuel.
That makes much more sense!
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Another great idea Doug! Tennessee or Kentucky?
some that good stuff you get from BEHIND the counter
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Unlabeled no doubt.
Ok I did a evap removal wiki. MP3 250: Removal of the evap canister and roll over valve
Probably needs lots of edits and help but it is a start.
stickyfrog wrote:
Unlabeled no doubt.
I'll have some samples for us in sept
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Looking forward to it. I am gonna need it I think. Just ordered over $500.00 in parts to change the VR and do all of the 12,000 mile service stuff plus replace the belt + rollers. Whew, it ain't cheap but is sure is worth it.
Gonna be down for awhile though...where did I put that pesky battery conditioner.
⬆️    About 5 years elapsed    ⬇️
@eakins avatar
2016 BV350
@eakins avatar
2016 BV350
On the 400, Is that same canister under the cover in the very front of the storage area (same cover has a cig lighter power port)?
I don't have that setup on my 400, but what looks to be the same black box up at the front. Same procedure?
Thnx!
@eakins avatar
2016 BV350
@eakins avatar
2016 BV350
Just found this thread for the 400 evap:
Where is Evap Canister on 400 -- Pics Added Below
⬆️    About 6 years elapsed    ⬇️
@mtoakey avatar
Florida Man
MP3 500 HPE Sport Advanced
Florida Man
@mtoakey avatar
Yes, Great pics, and an Air Compressor is a fantastic idea !!!
@night_wolf avatar
Waiting
@night_wolf avatar
Waiting
I pulled the evap cannister from my Moto Guzzi V85 TT & installed an air horn in that location Already have an air horn on hand, so would most likely do the same on the MP3 if I purchase it
2008 MP3 250
2008 MP3 250
Hello Sticky Frog. I see a Florida plate on that MP3. Also a St. Augustine Motosports frame. I see you are from Nashville In. but if you are ever in the North Florida area I sure would likr to meet you. I'm up here in Jacksonville and just getting into these MP3's. I've had my 08 250 for about 4 months now and still trying to get it running properly. Disconnecting the charcoal canister sounds like a great idea. My buddies has a 150 that he is having problems with do to the canister and the associated hoses. We need to get together. Tom
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
I lived in the St. Augustine area for 30 years and just moved to Indiana last year. My parents still live in Jacksonville but I have no idea when I will visit Florida. Probably not for a year or more.
[ Time: 0.2057s ][ Queries: 9 (0.1917s) ][ live ][ 318 ][ ThingOne ]
