@sarilka avatar
Silver GTS 250
@sarilka avatar
Silver GTS 250
Hi all,
I moved a couple of months ago, and haven't gotten a chance to ride my scooter in that time (2007 Vespa 250 GTS). Today I go to ride, try to get it started...and nothing.
Here are some details:
- The engine will try to turn over, but it won't catch.
- I have plenty of gas.
- It's about 80 degrees outside, but it hadn't been running previously
- the headlight comes on, and doesn't dim when I try to turn over the engine.
- flicked the kill switch back and forth, no workie
Suggestions on what to do next?
Also...this is the second time I've had scooter FAIL in the past year. Last summer, it wouldn't start, and 2 trips to the shop resulted in them replacing the battery twice and the regulator (?). I'm beginning to wonder if modern Vespas are just cursed.
50cc Black 2009 Honda Ruckus White 2010 Vespa GTS 300 Super
When was the last time you rode? If it was more then 2 weeks the battery maybe dead. If thats the case you just need to charge the battery and your good.
@aviator47 avatar
@aviator47 avatar
If the engine is turning over:
Step 1 - check for spark.
Step 2 is fuel delivery.
Al
@harvey avatar
@harvey avatar
First, I would check to see if my sparkplug cap has come loose.
Then, I would get a battery tender & charge the battery. I think it's a good idea if the scooter's been sitting for more than a couple weeks at a time & after a couple months it's probably discharged between 20% (maintenance free) to 60% (refillable).
I vote battery and you should keep it on a trickle charger. That said that's an awful lot of batteries to go thru. I still think you have something draining your battery. Are you sure they did the work they said they did?
[ Time: 0.0206s ][ Queries: 3 (0.0045s) ][ live ][ 334 ][ ThingOne ]
