GT200
GT200
My GT200 is once again stalling and once it stalls it is hard to start. I noticed that the mechanic did drill a hole in my gas cap and did detach the evap line that goes into the carburetor. As I inspected the gas line from the tank to the carburator, I notice that the fuel line that leaves the charcoal canister below the gas tank has an air bubble in it. I also notice that the in-line gas bulb filter is only half full of gasoline. Could this be why my scooter is stalling and if so, what do I have to do to get the air out and keep it from happening again. Any help is appreciated. Joe
Re: GT200 Stalls, hard to start
Pillock.
Not so daft.
Remove ALL the evap crap, have a proper vent from the tank, and get a new fuel cap.
@harvey avatar
@harvey avatar
Here's a better description of what the evap system is & does:
Dooglas wrote:
The evap system is designed so that gasoline fumes from the tank don't evaporate into the air. The system incorporates a charcoal cannister to collect vapor and a rollover valve to avoid liquid gasoline running out of the tank if the scooter is laying on its side. Liquid fuel in the cannister causes poor tank venting and can result in hard starting, rough running, or stalling. Having said all this, there is a tendency for riders to blame every possible rough running or stalling problem on the evap system. It is easy enough to disconnect the hose from the carb body and see if that makes a difference. If it doesn't, the problem was not the evap system. Every gasoline car and truck sold in the US for the past several decades has a similar system.
This is from the LX150 workshop manual, to give you a better idea of how it's setup:
If the Charcoal canister is filled with gas- it's a problem- it's intended to route gas vapours from the tank into the combustion chamber, it's not intended to deal with liquid fuel.
If you're overfilling the gas tank frequently try this filling method:
FAQ: How can I avoid overflowing the gas tank?
Good luck with it!
@tb avatar
@tb avatar
Good luck with it!
1+ Very clear, consise and comprehensive summary. Would recommend that anyone with questions regarding the issue of the Evap System to read this in its' entirety...reveiw the diagram and understand the Evap System system operates. There are links with pics (Wiki Library) on various stages of fix.
[ Time: 0.1844s ][ Queries: 7 (0.1736s) ][ live ][ 334 ][ ThingOne ]
