@680captain avatar
'80 P200E (with sidecar) and '06 GTS
@680captain avatar
I was just at a rally in Northern California and there were many people
with GPS mounts, some fitting behind windscreens.
I have a Garmin nuvi 255W, and a 2006 Vespa GTS, as well as a P200E.
What is the best mount for me to use? I would use it more on the GTS...
When you post your answer, provide a link to the product.
Thanks!
@bklwashere avatar
2006 Piaggio BV250
@bklwashere avatar
2006 Piaggio BV250
RAM mounts are very secure and customizable depending on how/where on the bike you want to mount. GPS City is a great place to order from. Here's a link.
@dannyh avatar
Resident Gentleman
Resident Gentleman
@dannyh avatar
Here's a thread that might be helpful:
GPS MOUNTS
@scutrbrau avatar
The Beer Guy
2010 GTS 300 Super and 2015 Kawasaki Versys 650 LT
The Beer Guy
@scutrbrau avatar
+1 on the RAM mount. I have one on my GTV for a Garmin nuvi 765. It is very solid.
@dunkvs125 avatar
Vespa s 125
@dunkvs125 avatar
Vespa s 125
Hi,
I had a Ram mount, but just had to sell it, i just hated the look of the bulky thing!
When not in use, it looks real ugly bolted to your mirror stem, and is a pain to keep taking off.
they work fine though!
@feb31st avatar
GTS 250, Sprint 150 & HPE Tech
@feb31st avatar
DunkVS125 wrote:
Hi,
I had issues with the mirror/stem /U-bolts. Mainly the plastic half moons would split, vibration, etc. The 7/16' nut was a pain in the ass to do/undo.
Had this "bridge" built for the Cannonball. Its really nothing more than a 1/2 inch split collar shaft into a piece of aluminum made to fit across with threaded RAM Mount balls every so many inches. Works great so far. Local fabricator made it for $60.
http://www.flickr.com/photos/feb31st/4884477673/
@stinkyjones avatar
@stinkyjones avatar
+1 on RAM mounts.
Although folks complain about the appearance of the ubolt, you can put a $10 ball on each scoot, and transfer the mount from one to the next effortlessly.
The RAM products are well built and do not vibrate if you install them in the right spot (i find it helps to put a small sliver of rubber material in there to keep it from twisting on the mirror stem).
@680captain avatar
@680captain avatar
Thanks!
The RAM mount was just ordered. Looking forward to getting it and putting it on!
GTS250ie Dragon red,GTS250ie Black
680captain wrote:
Thanks!
Which RAM mount did you order?Does it have a code?
@2011super avatar
2021 GTS 300 Touring
@2011super avatar
I use the stock mount that came with th Garmin 660 and it works perfectly.
@knight_train avatar
I've got the RAM mount as well. Pretty pleased with it.
@2011super avatar
@2011super avatar
I found my photos of the stock mount.
External inline image provided by member with no explanatory textExternal inline image provided by member with no explanatory text
@yelgib avatar
2008 GTS 250ie
@yelgib avatar
2008 GTS 250ie
My RAM Mount.
@dutch avatar
LXV 150 GTV 250
@dutch avatar
LXV 150 GTV 250
Garmin mount
Here's a picture of my RAM mount. The nice thing is when I take it off I
just have the clamp on my mirror stalk.
@steve avatar
'06 Vespa LX150, '07 Suzuki Burgman 400, '05 Honda Metropolitan
@steve avatar
I don't know if there is something similar for the GTS. I've got the Garmin nuvi 680 mounted to the brake reservoir using a Motorcycle Larry's replacement cover. It is then mounted using a RAM arm, mount, and bracket that I purchased at GPS City.
Here's my Garmin on my Burgman 400:
For more (or larger) images, go here
On the right reservoir cover I've mounted a Sirius Sportster 5 that I use on longer highway trips. My iPhone stays in my pocket, and I can use it via Bluetooth on the nuvi. I have the Autocom intercom tying it all togehter.
Hope that helps,
Steve
[ Time: 0.0174s ][ Queries: 4 (0.0048s) ][ live ][ 334 ][ ThingOne ]
