@xchrischassex avatar
2010 GTS 300 Super / 2007 GTS 250ie / 1977 Leyland Mini / 1966 Ford Galaxie / 1955 Ford / 2019 Mini Cooper S JCW / 2024 Nissan Pathfinder Rock Creek
My alignment on my ET4 is pretty off (about 1030ish). I'm hoping this is a pretty easy fix, and I assume it involves removing parts of the headset.
Advice/help is appreciated, pictures of the process even better!
Thanks all.
@dannyh avatar
Resident Gentleman
Resident Gentleman
@dannyh avatar
Nope. Not that hard. Just grasp your front wheel firmly between your legs and you should be able to turn your handlebars straight. It won't be real easy, but it can be done. You really shouldn't have to take anything apart.
Sounds like the same thing i did as a kid with my BMX bike..
This won't loosen it further or make it wobbly etc?
Thanks fyi!
@dannyh avatar
Resident Gentleman
Resident Gentleman
@dannyh avatar
Thanks fyi!
I straightened mine that way and it hasn't loosened. I've also read many posts here saying to do it that way, so I don't think there is any danger of it causing future problems.
Do it that way - but if it is very easy to turn to correct it, you may need to nip the pinch-bolt up a tad.
⚠️ Last edited by jimc on UTC; edited 1 time
@stinkyjones avatar
@stinkyjones avatar
Even easier, while sitting on it, you can turn it to full lock, and then apply pressure.
It actually need to be turned right.. So wouldn't it being in lock kinda mess it up if i try to jerk it out of lock? ya know?
@stinkyjones avatar
@stinkyjones avatar
I've done a great job of not being clear today . . . don't lock the bars with the key.
If the bars are say, skewed to the right, turn the bars all the way to the left, then apply pressure to the right grip until you get it where you want it.
Make sense?
I find it easier to do this than the leg method.
@bvbob avatar
@bvbob avatar
Make sense?
Have you actually tried this? My bars are slightly off to the right on my BV. I lightly tried the between the legs thing once and nothing budged. Isn't there a pin or something that prevents the bars from going too far? I sure don't want to bust something.
Bob
@stinkyjones avatar
@stinkyjones avatar
Make sense?
Bob
I've done it on both ET4 and GTV.
YMMV. I obviously am not taking responsibility for any damage.
@bvbob avatar
@bvbob avatar
Make sense?
Bob
Thanks. I'll probably try the between the legs version one more time. I was being very gentle the first time tried. I'll have beer first this go around.
@sallad avatar
GTS
@sallad avatar
GTS
Make sense?
+1
I've re-adjusted both ways, and this way, sitting on the bike, is far easier in my opinion.
[ Time: 0.0257s ][ Queries: 3 (0.0122s) ][ live ][ 318 ][ ThingOne ]
