The belt width seems not too important to check, since it is not deteriorating too much during its life ( at least up until 35000 km - 22000 miles what mine has now).
My theory so far is that they deteriorate from fatigue and thermal problems. Mine is in a constant environment where it is in the 70 to max 100 the whole year long. So no freezing temperatures what could make it hard on the belt material and maybe form micro cracks and micro separation between the top and the working layer during the initial cold start phase.
About the belt:
The belt has a new width from 26.2 mm and a replace width from 25 mm.
Well, I measure more 26.4 mm
With 26 mm after 18000 km the belt is nearly new.
Checking for cracks and defects I noticed a few threads missing in parts of the belt.
These are the worst parts
The belt at 31000 km 26.3 mm wide
The belt at 31000 km with much more little cracks and the white thread is gone totally on one side while the other one is still in good shape.
Funny, but the width of the belt got wider the last 13000 km.
Every tooth has now stress cracks inside but the performance is still as new so I will keep on testing...
after finding this picture,
I know it does not matter if the outer thread is gone, it is more important to check the belt for signs of separations and your finger can do that through the service opening in a second.
