Short of major surgery, is it possible (or worthwhile) to graft a fork from a later model ET4 onto a vintage large frame? Found the below locally and it features a disc brake. Don't know anything more than this at the moment and won't bother the seller unless I can determine if this conversion is viable. Thanks
Well seeing as I have access to manual and 4 axis CNC mills and lathes plus mig and tig welders I don't lack for the proper tools, just the knowledge! Thanks for the link to that thread, I'll check it out
its not as hard as you think ....
a mate put some into a sprint he said it was easier than he expected it to be ... just cutting and fitting the mudguard to fit and look good was the hard part....
kind of a cut and shut ..... im sure you can work it out if you have the tools you must know some engineering
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
