@bubbajon avatar
RIP: MP3 500 - Brutto Moto
@bubbajon avatar
Weird - my 500 has started to sound like it's missing going down the road sometimes. Nothing out of the ordinary I'll just be tooling along at a steady speed and it starts feeling like it's cutting out for a bit then it runs smooth again. New Iridium plugs in my last service about 2500 miles ago. I doubt the air filter is clogged.
Any ideas what to look at?
@roadcaptain avatar
PX200 GTS300
@roadcaptain avatar
PX200 GTS300
whip out and clean engine shut off button, also check plugs, just because they are new don't mean they work!
@mjm50cal avatar
Red MP3 500 RUBY DRAGON
@mjm50cal avatar
Is the bulb black or clear on the airbox?
when you last filled up , did you use the same gas station?
Have you ever cleaned the throttle body?
And I would check the air filter just to be sure.
@bubbajon avatar
@bubbajon avatar
All my switches and connections have had the clean, dielectric grease and seal treatment.
The bulb is clear. I lost my original bulb and made my own with tubing which I sealed at the bottom. Odd actually - I used to collect quite a bit of oil here.
I will check the plugs today.
I'll also clean the airfilter - I'll hate it but I'll do it.
Same gas station as usual - Costco 80% of the time.
I have not cleaned the throttle body. I have to completely remove the airbox to do this? If so I can get a can of cleaner (yes I know - not just carb cleaner) and git-r-done while the airbox is apart.
Bear in mind this isn't an all the time thing - just at add moments and seemingly when it shouldn't - at cruising speed around 50-60 mph or so. It doesn't stumble when I accelerate and in fact it seems to "clear its throat' when I do accelerate when it stumbles.
Looks like a maintenance day - hope the heat is reasonable today...
@cubsking99 avatar
2007 Yamaha Vino 125
@cubsking99 avatar
Maybe the problem is with fuel not getting to the engine all the time? While you're under the bike, check to make sure there's no kinks or other problems with the fuel lines.
I don't know if that could happen anyway, but if you're already working underneath it, it can't hurt to look...
Mark
@dkrz123 avatar
Honda CTX700N
@dkrz123 avatar
Honda CTX700N
Re: My 500 has started to "stumble"
At one point, mine started doing that too. Believe it or not, it turned out to be a loose connection at the battery terminal! Worth checking. Took all of 3 minutes to fix.
@g03 avatar
MP3 500 08
@g03 avatar
MP3 500 08
mine started similiar action, found the stop kill sw vibrated up some. Just flipped it twice and no more "ghost stalls"!
@bubbajon avatar
@bubbajon avatar
Good point - I need to check connections anyway.
@joyce avatar
fuoco 500
@joyce avatar
fuoco 500
Check the seat sensor. Mine was dropping power every now and then and Piaggio have now replaced the seat, touch wood everything seems to be OK now.
@deepfraught avatar
2007 Gilera Fuoco 500ie, 2005 Piaggio X9 Evolution 500ie
@deepfraught avatar
From the seat bypass thread, I was told the seat bypass sensor only applies during tilt lock.
So you could stand up while riding normally and it won't do anything... suggesting if it was faulty or not, it wouldn't do anything.
Currently I'm riding with it unplugged, and haven't wired in the bypass resistor yet.
Did Piaggio do anything else that might have solved the problem?
@fuzzy avatar
@fuzzy avatar
+ 1. On long rides I frequently stand up on the floor boards and never a problem with engine power. Also rev engine on the center stand, standing beside MP3 and tilt off.
@bubbajon avatar
@bubbajon avatar
+1 - it would cripple any bike to have a cutout if your butt comes off the seat. Logic should tell you the seat sensor is unlikely at speed.
I pulled the plugs yesterday. One of 'em damn near gave me a heart attack putting it in - it was acting like I'd stripped it but it finally tightened up. *whew*!! Anyway I gotta say these engines make no sense to me - they have an ECU that supposedly runs lean - so why are my plugs black? They were black on the first plugs too. I have the Iridium plugs and the insulator is white near the electrode but gets black deeper in and around the body where it's exposed in the combustion chamber. Weird. Anyway I haven't had the issue in a bit - I'm wondering if it's just the heat - perhaps it's the freeway running after I've been stuck in traffic a bit. I'll need to pay more attention what has occurred before the stumbling...
Gilera Fuoco 500
Gilera Fuoco 500
my Fuoco is stalling too...
glad to read your post - have been meaning to write too.
I have the same problem.
whilst driving (for example autobahn 80mph or B-roads 50-60mph) at about 3/4 throttle, every now and then the scooter just cuts out, chokes...as if someone abruptly turns the gas throttle back to its zero position. as you can imagine, it's extremely unnerving, when overtaking someone with oncoming traffic.
I have been to my dealers - had a new battery fitted; new plugs too.
I will have a look at the air filter as well, just to be sure.
I just don't know if it's a software problem, a hardware problem (a faulty switch for example), or a fuel supply prolem.
what else can I do?
@bubbajon avatar
@bubbajon avatar
Just to be clear mine isn't like a cutting out problem - more like a fuel delivery problem - like I'm about to run out of gas sort of stumble.
@bubbajon avatar
@bubbajon avatar
Re: my Fuoco is stalling too...
what else can I do?
Yours sounds like the "classic" run switch issue. Try cleaning it and putting dielectric grease on the contacts. It's about a 15 minute job tops.
@deepfraught avatar
@deepfraught avatar
Welcome Urzwoo,
General troubleshooting approach is to look at fuel and spark for combustion, and for EFI battery electricity for ECU, fuel pump etc.
The abrupt cut could be loss of ignition, by bad high tension leads or connection to spark plugs, or to coil/igniter at other end.
Loose or poor electrical connections at fuses and connectors could cause electrical glitch cutting ignition (edit: like kill switch said above)
Experience helps where you check first, but something such as a faulty throttle position sensor, and ultimately all diagnosis suggests swapping out the ECU. If you have a friend with the same bike, comparing suspect parts and swapping between test rides is a great economical diagnosis.
BubbaJon, I'm not sure what effect an imperfect plug chop has on the reading to a perfect one, e.g. how much of the deceleration and idle combustion affects the plugs before you kill the engine.
I've heard on bikes to do the perfect plug chop for any riding condition, e.g. WOT, pull the clutch and kill the engine at the same time. You don't want overrun combustion or idle off throttle combustion to taint the reading.
I imagine for ours you would just have to kill the ignition, hoping the revs drop and the clutch disengages.
After talking about going to advanced rider training and to the track, I thought I'd like to get a dyno run to see the A/F ratios before doing more consistent WOT at a track day, as on the street it's only for a few moments.
Gilera Fuoco 500
Gilera Fuoco 500
thanks!
deepfraught wrote:
Welcome Urzwoo,
wow. sounds a bit complicated, all that.
now i just need to try and translate into german (i'm an english guy in germany!) and take it to my local workshop.
the "run switch" that BubbaJon mentioned...is that the motor kill switch?
thanks for all your help!
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
Was the engine cold? Never take plugs out of a hot or even warm engine. I know Ford and GM both have SSM (Special Server Message) About not removing plugs on any vehicle with aluminum unless the motor is cold. It states to only remove plugs when the engines are cold, to prevent galling of the threads in the head.
@deepfraught avatar
@deepfraught avatar
Re: thanks!
I wouldn't take that to the dealer, that was more targeted to your own diagnosis. The workshop manaul has the troubelshooting diagnosis that would follow similar paths.
The tip from BubbaJon about the kill switch is probably first place to check.
Gilera Fuoco 500
Gilera Fuoco 500
Re: thanks!
i do actually have the manuals - i'll have a finger through them.
are a lot of jobs on the scooter ones that those not that mechanically minded can do, or is everything best left to the "experts"?
will certainly take a look at the kill switch!
regards from munich.
@bubbajon avatar
@bubbajon avatar
Yep - stone cold. I dunno what the deal was it would tighten up and feel like it was about to set and then it would free-fall. It would take a few more quarter turns and do it again. I *swear* it acted just like a stripped thread. Then it set for real. I would almost suspect cross-threaded but it wasn't that difficult to turn.
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
Get a spark plug tap and run it in the hole.
you could have a plug or both going bad. The richness was eliminated when I went to the k&n and it leaned out nicely but not too lean.
@larrylarry75 avatar
2009 MP3-500 aka Red Dog 2007 Vespa 250ie
Jon...jon...ride 'em hard and trade 'em....
LL75 ROFL emoticon
@mjm50cal avatar
@mjm50cal avatar
Jon, the beers are for you
@luthorhuss avatar
@luthorhuss avatar
Hey Bubbajon,
I called OAD yesterday and reported that mine is doing EXACTLY the same thing (without seeing this post first). Interesting considering ours are within a few months of the same age . I think, as OAD and I talked about, that it is prolly the throttle body. OAD and I just got thru giving my a real good run thru...changed oil, oil filter, checked plugs, cleaned air filter, and put on a new graphite bushing on the exhaust. I, like you, have not cleaned my throttle body yet and considering everything else that we went thru, it sounds like the culprit. Mine will shut on/off like it's cold when you first start it, which isn't so bad, but then going down the road it will occassionally stumble as you put it like it's not getting gas. Along with the throttle body, I'm also gonna put in some fuel injector cleaner which i was doing but have dropped off from...bad habit I know.
Luthorhuss are you going to be able to come by this week and do the work over here?
@luthorhuss avatar
@luthorhuss avatar
Maybe...If I do, I will bring my lil video camera. I will have to call you and find a good time between work/classes and all.
@bubbajon avatar
@bubbajon avatar
luthorhuss wrote:
Hey Bubbajon,
Thanks Shawn - I bet you're right and will get some cleaner and do that sometime this week. I'm praying I can get a rescheduled appointment and make the Maggie Valley run but... anyway - gotta be prepared in case!
@fuzzy avatar
@fuzzy avatar
Cheeky Thomas had a great post with pictures a while back showing what needs cleaning.
@yayadave avatar
MP3 500 - GTV250
@yayadave avatar
MP3 500 - GTV250
That throttle body cleaning sounds like a good move, but I'm wondering if you tried a little dry gas and if you got rid of the evaporator lump?
@bubbajon avatar
@bubbajon avatar
LOL - no - I'm leaving that in until my extended warranty is history - exactly the moment it's paid off! Then I can do what I damn well wanna.
dry gas is mostly ethanol and you get enough of that already at most gas stations. Ethanol abosrbs water.
@luthorhuss avatar
@luthorhuss avatar
I removed my evap cannister long ago.
Fuoco 500ie
Fuoco 500ie
Having the same problem faced by BubbaJon.
Going to have my plugs, kill switch and battery connections checked later.
Hopefully it'll remedy the problem.
Any other suggestions bubba?
@stooterboy avatar
MP3 500
@stooterboy avatar
MP3 500
If you are saying you are going to tell the dealer what to check, DON"T, you will waste money. You tell the dealer what to check and that is what they check and you get bill for time whether that fixes it or not.
Always just explain the problem to the dealer and let them do the testing, can save you lots of money. Then if they can't find the problem, suggest stuff "you have heard could be the issue" if they haven't checked those items.
We use to get people in the dealer all the time telling us what to check and then they get all pissed off when that didn't fix the problem. Then we did our standard diagnostic once we got permission, and found the problem for a 1/3 of the price it took to check everything they wanted checked.
So, explain problem, and let the dealer decide course of action first and if that doesn't work, then make suggestions.
2009 MP3 400
2009 MP3 400
+1 ScooterBoy
[ Time: 0.0385s ][ Queries: 3 (0.0203s) ][ live ][ 313 ][ ThingOne ]
