Fly 150
Fly 150
Was standing still at a red light - my Fly 150 just died abruptly.
Switched to a brand new battery
Ignition on => headlights on
Kill switch on
Pressing brake - no brake light!?
Pressing start - nothing happens, not even a click
Checked bulb for the brake light with multimeter - ok
If the brake switch failed, i.e. not registering that I was braking - why would it have died abruptly when I was idling at the redlight. That doesn't make sense to me.
Would a broken kill switch cause the brake light not to come on?
Or do you think it's the brake switch?
Fly 150
Fly 150
Update:
Brake light doesn't work for either left or right brake
Turn signals doesn't work
Horn does work
Headlight works
Think it's the kill switch.
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Have you checked the fuses 4x behind horn cover
@masala avatar
@masala avatar
946
zak22 wrote:
Update:
Horn does work
Headlight works
I agree.
Fly 150
Fly 150
The 4 fuses in the front are all ok.
Went to dealer and picked up a new kill switch for $23
....hopefully that will fix it.
Fly 150
Fly 150
Replaced kill switch => Problem solved!
[ Time: 0.0113s ][ Queries: 3 (0.0043s) ][ live ][ 334 ][ ThingOne ]
