What is it?
The Fuzzy Washer is a thin precision 1mm thick washer that is inserted next to the stock variator spacer washer on 400 & 500 MP3's. It will also work on similar scooters I have one report of a BV500. Up to two can be inserted for different levels of performance. Some folks prefer one, others prefer two. It works by spacing the pulley apart which in effect lowers your gear ratio. This translates into faster acceleration with only a slight penalty in top speed. Since the top speed is around 90 mph it''s a safe bet this isn't a concern.
Worth is relative to each individual. I do seem to recall one person seemed to think that it wasn't worth it. The rest of us had an ear-splitting grin the first time we twisted the throttle. I bet most still do.
I have reports from 2 users, one with a 500 - the other with a 400. They tell me it works great! But I cannot personally vouch for this as I do not have a JCosta installed.
I can in fact vouch for these. I have tried 16, 17 and 19 gram weights and I have settled on the 17 as the optimum for my tastes. To my mind the Dr. Pulley and Fuzzy Washer compliment each other very well indeed.
You have to disassemble your transmission to the same point as if you were replacing your drive belt. Many users install their Fuzzy Washer at the time their belts are replaced. You can also do the job yourself at any time. It's not complicated and there are several threads on the Modern Vespa MP3 forum describing in detail how to do it.
A couple of users (including me) have reported the belt rubbing. This has so far been isolated to scooters with the old style belt which has higher "teeth" on the outer side. The belt tends to ride higher in the pulley at idle and with the old style belts it may rub. The typical rub spot is the rear of the transmission cover at the rear. A little grinding will eliminate the problem or change to the new style belt - which most scooters have anyway. This has also been covered in a MP3 forum post and is considered a minor issue. I do feel it's my responsibility to inform potential buyers and I assume no liability for any installation issues. I sold a 100 the last issue and only 3 or 4 people reported any rubbing.
The cost is $11 for the first washer and $10 for a second washer. This is postpaid anywhere worldwide.
Send funds via PayPal to jon@rezolutionphoto.com
Use the personal option so that I do not incur fees.
Attach a note to the PayPal transaction stating your MV user name, your real name and mailing address.
