⚠️ Last edited by Papa Bear on UTC; edited 3 times
Problem with the steel?
It is too early to say what has happened, but my supplier, for the J. Costa Variator, is moving very quickly, to take care of my problem. No damage has been done, to my MP-3. Sure is a good idea, to get those scooters, in for service, when it is time. I drove it in, for service (about 55 miles) and it ran perfectly.
G03 wrote: What is the issue? not stated above? |
Sounds like the Bell has cracked like Jim C's did, it bet it is the early type black one. The new type are Stainless Steel.
Soeley wrote: Sounds like the Bell has cracked like Jim C's did, it bet it is the early type black one. The new type are Stainless Steel. |
Posts: 6252 Location: South Cumberland Plateau in Tennessee |
Put some Dr Pulley sliders in and a Fuzzy Washer and you may not miss the J-Costa that much.
[quote="Rob In Denver"]Put the OEM back in the meanwhile, or maybe you did that already?[/quote
Then, I would have to pay to have the J. Costa, installed, when the bell gets here. If I did the work, myself, it would definitely make sense. I do have the OEM one. Maybe, I should learn how, since a disaster, was avoided this time, by an alert mechanic. We need to keep an eye on these 8,000 RPM Time bombs. |
Yours is the old model right?? If it is the new one we all need to know about it, but otherwise it is a known issue.
I am guessing Spain slacks off ( if it does) in August like Italy, to avoid the heat, so maybe you won't have a month to wait, just a couple weeks. At any rate, hope it is back on the road soon. |
Rob In Denver wrote: Yours is the old model right?? If it is the new one we all need to know about it, but otherwise it is a known issue. I am guessing Spain slacks off ( if it does) in August like Italy, to avoid the heat, so maybe you won't have a month to wait, just a couple weeks. At any rate, hope it is back on the road soon. |
More about the 10,000 mile service. Front brakes were 50% and rear were 75%. I have never had, to do brakes. The valve adjustment, was perfect. Nothing had to been changed.
Fuzzy wrote: Put some Dr Pulley sliders in and a Fuzzy Washer and you may not miss the J-Costa that much. |
Papa Bear wrote: Fuzzy wrote: Put some Dr Pulley sliders in and a Fuzzy Washer and you may not miss the J-Costa that much. Dr. Pulley Sliders Speak up! Your results with the new thinner Fuzzy Washer I'll have a new batch of Fuzzy Washers in next week. You can order the sliders direct from Paul at Dr. Pulley for about $65 and it takes a week to get here. |
Papa Bear wrote: Rob In Denver wrote: Put the OEM back in the meanwhile, or maybe you did that already? I even have a set of sliders if the size is the same for the 500 and the 400. If you like 'em you can buy me a replacement set. |
BubbaJon wrote: Papa Bear wrote: Rob In Denver wrote: Put the OEM back in the meanwhile, or maybe you did that already? I even have a set of sliders if the size is the same for the 500 and the 400. If you like 'em you can buy me a replacement set. |
BubbaJon wrote: Papa Bear wrote: Fuzzy wrote: Put some Dr Pulley sliders in and a Fuzzy Washer and you may not miss the J-Costa that much. Dr. Pulley Sliders Speak up! Your results with the new thinner Fuzzy Washer I'll have a new batch of Fuzzy Washers in next week. You can order the sliders direct from Paul at Dr. Pulley for about $65 and it takes a week to get here. |
