OK lot of double meaning words in subject, I was about to install jet in carb , last screw I stripped the phillips part, would like least expensive way out of this. Also where i don't drill into the carb. Thank You Man!
Thank You Man!
I would try needle nose pliers, the small long nose type Snap-On sells. 8)
Get an impact screwdriver, it is an essential tool. If there is any sign of the Phillips cross left on that injured screw, this driver should loosen it:
The bowl screws?
Very soft... ( I learned that one)
Is the head completely gone?
If so remove the other 3 screws, remove the bowl and use plier/vice grips to remove screw.
If there is still some head left on the screw use an hacksaw and cut a new slot in what is left of the head and using a firm downward pressure back out the screw with a flat head screw driver...
Dremel tool is your best friend for some situations like above.
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
