@makenzi avatar
ET3 Primavera
@makenzi avatar
ET3 Primavera
Okay I have this great 1985 Pink PX80 and I had to put the corsa racing seat on it in order to be able to reach the ground. I am curious if I can do a single seat on this frame? or do I have do the longer "bench" seats? and if I can what would you recommend as the "thinest" seat so I can still reach.
thanks!
@koenig_blues avatar
here u go girl
slim bench
single slim
@jsharpphoto avatar
1974 Vespa Sprint Veloce, 1963 VBB 180 Custom
@jsharpphoto avatar
if you get the regular 60-70's style saddle seat, it will definitely fit. The saddle seat actually sits HIGHER than most bench seats.
@scooter_west avatar
Sponsor
Sponsor
Agreed. Your Corsa will be lower than saddle seat. But, a saddle seat will fit your P-series.
@hotboxdeluxe avatar
'09 S50, '79 V50
'09 S50, '79 V50
koenig blues wrote:
Ebeth is that seat off-the-shelf or custom made? I like!
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
lower than a ten
just a question .... can you reach the floor with the seat up or off sitting on the tank?????
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Re: lower than a ten
Good question Bitsa. It could all be for naught.
PS - I don't want to harp on this too much, but really, in theory, you should always be able to reach the ground with one foot given a tilt of the scooter to the side.
@shawn45 avatar
1979 P125x, 1980 P200E
@shawn45 avatar
So does this mean you are keeping the scooter?
@demo_nic avatar
ET3
@demo_nic avatar
ET3
Speaking from a fellow shortie, I use the Corsa seat and I thought it would be a problem since I was tiptoeing the ground. Once I actually got on and started riding instead of gauging from sitting at a standstill, I found that slipping on and off was actually very easy. BTW here is a tip: When getting your vespa off the center stand, stand in the middle with each foot on either side of the center and lean forward. If you try to kick the center stand off from the side, you will tip over with the scooter. >.< I know it's intimidating especially if you have never ridden a manual before and your sense of safety wants you to have both feet flat on the ground while on the seat, but it is possible to ride if you can get one foot down with only a slight tilt. Just try it before you give up on your PX80.
BTW what is your inseam? Mine is 25" so it is totally manageable if yours is that or more.
@makenzi avatar
ET3 Primavera
@makenzi avatar
ET3 Primavera
yeah i just cant part with it lol
I am like a 26" inseam i think.. i love the look of the seat on the red one!
@makenzi avatar
ET3 Primavera
@makenzi avatar
ET3 Primavera
koenig blues wrote:
here u go girl
slim bench
wowza! i love that! that is EXACTLY what i want!
did you make it or buy it from somewhere?
@makenzi avatar
ET3 Primavera
@makenzi avatar
ET3 Primavera
let me know! i would love to get my hands on this seat
@shawn45 avatar
@shawn45 avatar
Better yet, do it in style, put it in neutral, start the bike, jump on and sit down with both feet on the foot rails, grab the clutch shift into first and give it some gas and off you go. No need to rock the bike forward. If in a tight spot, give it enough gas to get it moving then quickly pull in the clutch again to kill the forward momentum and use your front break in need be. Then put a foot down to steady yourself in order to back the bike up now that you are off the stands.
its a custom seat very east to make (even i can make it less then a hour) all u need is a seat foam (buy the one that have leght similar to ur vespa seat) a used seat plate, a leather skin
step 1. cut the foam to be as low as u wish
step 2. glued the foam to the seat plate
step 3. wrap it with a leather skin
step 4. put the seat holder to the pk frame
step 5. have fun joy joy in ride
good luck and have fun girl
ps: adam like i said above its a custom seat almost similar with what u do to ur wife vespa seat i learn it from u actualy Razz emoticon
@makenzi avatar
ET3 Primavera
@makenzi avatar
ET3 Primavera
Yes and I can reach with the corsa but not much. Which is why I wanna go a bit thinner
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
water slide
im sure you could get one made .... i had one done for mine .. not cos ive got e.t's legs but the tank was in the way ... then i took it to an upholsterers and he made it look cool ..... it even lifts up backwards
[ Time: 0.0182s ][ Queries: 3 (0.0042s) ][ live ][ 334 ][ ThingOne ]
