I just put a new windscreen on my GTV. There's not a whole lot of space available on the handlebars to mount a bracket, with the brakes, cables and whatall already on there. Apparently in tugging at the cables to make a bit of room for the bracket I must have pulled something loose. Now when I try to start it, it will only work with the right brake engaged but not with the left. Before I go pulling things apart to try to solve the problem I thought I'd check here first so you all can tell me I'm missing something very simple.
Coincidentally, when I did start it for the first time after the windshield installation, it idled roughly for a minute. It wouldn't maintain steady revs, but went up and down. It idled low enough that I thought it might stall out. After getting on and giving it some gas a few times that problem went away but it was kind of strange. Related or weird coincidence?
TIA for any advice, suggestions, ridicule, etc.
