vespa px 125
vespa px 125
hi all,i was wondering if any one could help find out my problem,my problem is when i change into third i get a bucking bronco effect which seems quite harsh on the gears, any ideas???
Moved to where those who can best help hang out.
vespa px 125
vespa px 125
cheers jim..
@roadcaptain avatar
PX200 GTS300
@roadcaptain avatar
PX200 GTS300
cruxiform is fecked
vespa px 125
vespa px 125
cheers..that what i was thinking...... is that an expensive job??
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Not to do yourself. I imagine it's almost as expensive as they get to pay a mechanic. It involves dropping the engine and splitting the cases.
Not expensive or all that hard to do yourself, but it's definitely time consuming.
@astromags avatar
@astromags avatar
Please check your cable adjustments first. I was having the same problem, and was about to tear into it, when it was suggested my cables were out of whack. A few twists of the cable barrel adjusters and problem solved. It took a few tries to get it just right.
You may not be so lucky, but it is worth fiddling with.
Look for a recent post called Cruciform Lifespan. There is a helpful link to cable adjusting in there.
@n8murphy avatar
62 vbb ratbike, 64 vbb,56 bella r201
@n8murphy avatar
you don't need to remove your engine just split the cases and replace the cruciform with the engine in the frame. if you are only having an issue with third gear the teeth or the inside of the gear where the cruciform contacts it could be chipped or worn.
[ Time: 0.0153s ][ Queries: 3 (0.0050s) ][ live ][ 343 ][ ThingOne ]
