ET4 125
ET4 125
Hi All,
I've noticed three tubes on my ET4 that exit next to the engine that I don't remember seeing before. Everything seems to be working as normal. Should they be there? They appear to come from the back of the scooter and are clipped to the chassis next to the storage compartment on their way down.
@roadcaptain avatar
PX200 GTS300
@roadcaptain avatar
PX200 GTS300
drain hoses and should be there
@dougl avatar
El Macho
KTM Super Duke 1290, Vespa GTS 300
El Macho
@dougl avatar
The clear one is a battery vent. One of the black ones is an overflow from the fuel tank. If you look through the filler you will see a hole near the top. If you fill fuel over this hole it will run out the bottom of the scooter....
ET4 125
ET4 125
Thanks for your help guys. I see what you mean about the fuel overflow point.
Looks like I don't need to worry then.
[ Time: 0.0144s ][ Queries: 4 (0.0080s) ][ live ][ 318 ][ ThingOne ]
