2005 Px150(Black) and 1983 P200
So i have it running like a champ all summer,
a few days ago it developped a bog at WOT on uphills, when it used to never have that. I had that bog at the beggining of the summer, but since i drilled a hole in the air filter (heart shaped), that was forever gone...till now
Im talking sito plus and upjet. with the heart shape removed in the filter.
The temps have gotten on average 5-8 degrees C cooler than July....
And the bog feels like a rich bog (i can smell the gas)
My question is, how do cooler temperatures, given the same amount of fuel cause a rich bog? Would that not lean the mix out?
It only happens on uphills...under heavy load...the kind of speed where im at max WOT, on an uphill, neither accelaerating or decelerating.
@nigelthefish avatar
ET2, PX150
ET2, PX150
So what jets are you running?
@aviator47 avatar
@aviator47 avatar
Have you checked your spark plug?
@scooter_west avatar
Sponsor
Sponsor
Those Dellorto SI carbs don't seem very sensitive to temperature changes in my experience. I'd be surprised if 5-8 degrees made any difference at all. I know I've ridden to work at 60 degrees and home at 90 degrees without any real difference. I'd investigate other issues. We usually upjet from a 98 to a 102 with the Sito Plus on a PX150. I've not done the air filter mod before.
To answer your question about jetting; cold air is denser than hot air so cold air would add more air, leaning out the mixture.
thanks for all the replies..
finnally checked the plug
est elle couleur chocolat.....after a nice wot run
so i guess im good...maybe when i run wot an extended period on uphills it runs out of fuel to the carb?
[ Time: 0.0137s ][ Queries: 3 (0.0071s) ][ live ][ 343 ][ ThingOne ]
