willmw wrote:
Curious to know if it was a SymaxII you needed the part for.
I just had my SymaxII latching mechanism break/fail (hung closed and wouldn't open) on Monday, ordered a new one Monday evening from NewEnough and it was delivered to my door before lunchtime Wednesday.
I'm definitely sold on NewEnough, but I'm less than happy with HJC as this helmet was less than 2 years old. That said, however, I'm a creature of habit and otherwise like the SymaxII, and that's why I got another.
Yeah - it was a real piddly part. If you look on the inside-sides where the inner visor pivots at the end you'll see a little white ring. That is actually on a plastic post that's on a black rectangular piece of plastic held on by a rivet that passes from the outside under the chin piece hinge. The rivet popped off, the plastic piece fell down and the white ring disappeared. While I was looking for it, I took the liner out and noticed a crack in the helmet foam lining. That was enough for me to contact HJC and then on to New Enough.
I also bought a replacement Symax II - I'm just real happy with the way it fits, the noise level is acceptable and it has the features I care about.
I'm with you on the quality issues though - I would think for the price point they would A) build it better (think finish not flimsy or unsafe) and B) warranty it longer (seems that 1 year is their warranty).
My new helmet doesn't have quite the nice finish as my first one - like the top vent isn't quite flush - and I've had one issue with an interior liner snap (tight fit). They do say that the helmet hinge should be replaced every 2 years or if the visor ratcheting gets "soft" - but I've not heard about the latch itself - mine has worked flawlessly.
