@monit avatar
GTS 300
@monit avatar
GTS 300
The technical term for having your plastic chromed is vacuum metalizing. The process is exactly the same as preparing the part to paint so I've also included that process here too.
The steps to prepare for chrome or paint:
Remove the plastic part and clean with wax and grease remover
Scuff with Scotch-Brite Hand Pad 7448 (grey) and clean with wax and grease remover
Spray on a couple of coats of plastic primer, available in a pressure pack
Do not sand plastic primer
Spray on several coats of primer filler, available in a pressure pack
Spray a fine mist of dark color paint over the primer as a guide coat
Wait for both the primer filler & guide coat to dry completely
Using soapy water rub the primer filler with 800 grit wet & dry sandpaper
Continue sanding until you have removed the entire guide coat
Once done it's time to hand it over to your vacuum metalizing specialist
OR
Extra steps for paint:
Clean with wax grease remover
Paint several coats of your scooter color, available in pressure pack
Do not sand between coats of color
When dry spray with several coats of clear
Some Vespa plastic parts are textured. This is to hide fine scratches caused from general use and your primer filler will fill these.
These are the pressure packs I used. The one on the far left is filled with the color of my scooter and your automotive paint distributor should be able to supply one for your scooter.
You can now chrome or paint items like these. The rule is; the smoother you prepare the surface, the better the chrome or paint finish will be.
@masala avatar
@masala avatar
946
That is seriously hardcore, man! Your bike never ceases to amaze...
@koenig_blues avatar
awesome Nerd emoticon
@scutrbrau avatar
The Beer Guy
2010 GTS 300 Super and 2015 Kawasaki Versys 650 LT
The Beer Guy
@scutrbrau avatar
That's beautiful. Looks like another possible winter project for me.
@neops avatar
PX 200 FD (in pink)
@neops avatar
PX 200 FD (in pink)
Very interesting. How does it react whith petrol spills?
Is it durable or extra care is needed during the refill?
@monit avatar
GTS 300
@monit avatar
GTS 300
The chrome on plastic is sealed with a 2Pack clear coat to protect it. You maintain it the same as any automotive paint. In fact it works the same as the paint on a modern car so it's resistant to petrol spills.
⚠️ Last edited by Monit on UTC; edited 1 time
@neops avatar
PX 200 FD (in pink)
@neops avatar
PX 200 FD (in pink)
Great. Thanks a lot.
This just made it to no1 of my winter projects!
@neops avatar
PX 200 FD (in pink)
@neops avatar
PX 200 FD (in pink)
Well. So I tried but....
I tried to do this on my GTS/
I thought that it would be easier to start with something easier and not so rough so...
Here is what I did
I dissmantled the fron "tie" and washed it with degreaser, waited for it to dy for a day.
Sanded the panel, primed it and sanded again.
Sprayed with duplicolor for 2 layers (1 hour interval each) and then sprayed with lacquer 2 times (4hours interval each).
I am satisfied with the outcome, but there has to be something wrong with the paint I used, cause I just did not get that chome finish I wanted, just a silver(ish) colour - and the rattle can was a "chrome finish" one. What The? emoticon
Other than that, the paint is ok, with some "orange skin" effect, but it's ok I guess.
Besides I am thinking of a total respray of my GTS (in British Racing Green ) so no harm done...
Did I do something wrong or it's just a lousy quality spray that made it silver and not chrome?
Thanks in advance
@neops avatar
PX 200 FD (in pink)
@neops avatar
PX 200 FD (in pink)
Here is a closer one!
Wha? emoticon
No chrome!
I know I was supposed to chrome it, but I thought that the spray would have the same result/
Any ideas on what went wrong?
To moderators
If this post is a spoiler to the chrome issue feel free to delete. It is just that the OP seems to know about such stuff!
@michael_h avatar
2006 LX150 "Amadora"
@michael_h avatar
Wha? emoticon
No chrome!
It doesn't look bad, but not chromed. That is pretty close to the "chrome" look I received when using the spray paint option on some wheels a while back. It comes out silver, not chromed. Nice enough, but not chromed.
The difference, I believe, is not sending it out for the final chroming step.
@michael_h avatar
@michael_h avatar
Neops wrote:
To moderators
No problems.
@neops avatar
PX 200 FD (in pink)
@neops avatar
PX 200 FD (in pink)
Unfortunatelly, this is the step that I didn't want to take.
I somehow expected that I would "chrome" the panel and have everyone impressed with my ninja spraying skills...
Oh well... you can not always win
(thanks for the reply)
@monit avatar
GTS 300
@monit avatar
GTS 300
Oh dear, I'll take the blame for my poor instructions. I'm sorry. I see you have already received some replies from others so there's no need for my input too.
If it's any consolation I think the silver looks bloody fantastic against the main color and already a great improvement to your scooter.
There are also companies that can sell you a do it yourself chrome kit. It's everything I've been saying except you don't send it out. Check out this link: http://hmswarehouse.com/alsachrome.htm
Gary
@neops avatar
PX 200 FD (in pink)
@neops avatar
PX 200 FD (in pink)
Everything is OK.
Thanks for the input.
Btw I just buffed and waxed the silver paint and it looks great.
I'll keep it this way!
@monit avatar
GTS 300
@monit avatar
GTS 300
Neops wrote:
Everything is OK.
I'm very happy (and relieved) it all worked out well in the end.
Gary
@karmann avatar
2007 Avio Grey GTV
@karmann avatar
2007 Avio Grey GTV
Neops - you can actually purchase that part already chromed.
http://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/GTS-Chrome-Plastic-Horn-Cover/681
[ Time: 0.0148s ][ Queries: 4 (0.0086s) ][ live ][ 334 ][ ThingOne ]
