Unfortunately Dr.Pulley eBay trader doesn't provide service to my country so only other available choice was Malossi that is available virtually in any scooter store in this part of the world. My goal was 17g rollers but they aren't ever available in stock so I bought 16g that are widely available.
And they are quite cheap, about 25 USD for 8 pcs. set.
Today my mechanic find some time to replace them (after 13k km original rollers are still in good condition) and moment of truth was finally here
On last service dealer replaces many parts under warranty and one of them was new clutch set with a little bit harder springs (from Beverly 500 Cruiser) so Fuoco starts on 2800 rpm (about 200 rpm higher than before) - I'm a quite big boy and with this update most of vibrations while transitioning are gone.
Now they are completely gone and main reason is that from 0-100 km/h engine works on about 500-600 rpm higher revs than before so that "torque hole" between 2800-3000 rpm is quickly avoided cause at 30 km/h engine is already at 3600 rpm
Overall improvements are absolutely fantastic - Fuoco's throttle is much more controllable at low speed than before, acceleration is amazing, engine now sounds much "healthier" while speeding and all improvements ends at about 100 km/h after everything is like before so it didn't loose any of top speed.
My only conclusion ( from my point of view ) that this is perfect setup for my taste/weight
And there's few cons (but little ones):
- didn't notice significant improvements on engine braking after releasing throttle but it suddenly (braking) disengaged at about 20 km/h like someone manually press clutch.
- on slippery road rider must be much easier with throttle
Overall - perfect, absolutely fantastic and cheap (about 50 USD in total) performance upgrade
