![]() UTC
2012 BV 350
Posts: 2091 Location: Vestavia Hills, AL |
I was checking the fluid level in my radiator when I heard the screw plate fall. I tried to retrieve it with my magnetic tool, but no luck. Other than a scooter shop is there any where else I might buy this plate?
![]() UTC
2012 BV 350
Another possibility is does any one know what is the size of the screw? Maybe I'll buy a nut, glue it to the bottom of the bracket with blue Loctite. I've found part #'s, but do not see sizes listed.
screw = 257404-3 plate = 254485-4 |
![]() Vespa GTS 300 Super & Vespa P125X
Posts: 4134 Location: St. Petersburg Florida |
You can get them at any hardware store in the hardware section. I have a box of them in the basement.
![]() UTC
2012 BV 350
VEZPA wrote: You can get them at any hardware store in the hardware section. I have a box of them in the basement. |
![]() UTC
2012 BV 350
ScooterGirlinAL wrote: VEZPA wrote: You can get them at any hardware store in the hardware section. I have a box of them in the basement. ![]() ![]() http://www.thefastenerwarehouse.com/catalog/item/568857/215108.htm
Positive
![]() UTC
2012 BV 350
VEZPA wrote: They are a type of nut called a "speed nut" Take the one off the other side to match it up. Buy a few as you will probably need and use them later. When you put them on squeeze them together to make them tight. Also having a magnet on it during the install will make sure if you lose it the magnet grabs it. |
ScooterGirlinAL wrote: VEZPA wrote: They are a type of nut called a "speed nut" Take the one off the other side to match it up. Buy a few as you will probably need and use them later. When you put them on squeeze them together to make them tight. Also having a magnet on it during the install will make sure if you lose it the magnet grabs it. |
You can also email me your address and I will mail you one no charge from the shop in the morning.
Best, SDG
Positive
![]() UTC
2012 BV 350
SDG wrote: You can also email me your address and I will mail you one no charge from the shop in the morning. Best, SDG I have sent a PM with my address info. Thanks so much for your help! |
Or you can find them in the hardware dept of Lowes or Home Depot. A small pack is around $1.50-$2.00.
![]() UTC
2012 BV 350
XLR8 wrote: Or you can find them in the hardware dept of Lowes or Home Depot. A small pack is around $1.50-$2.00. |
ScooterGirlinAL wrote: XLR8 wrote: Or you can find them in the hardware dept of Lowes or Home Depot. A small pack is around $1.50-$2.00. |
![]() UTC
2012 BV 350
XLR8 wrote: ScooterGirlinAL wrote: XLR8 wrote: Or you can find them in the hardware dept of Lowes or Home Depot. A small pack is around $1.50-$2.00. David. thanks for the generous offer to mail the part! |
![]() UTC
2012 BV 350
Well, Jiminy Crickets, I got home to put the speed nut on and it was too wide to fit through the tab. I went back to Lowes this evening so hopefully I'll have success in the morning. I didn't take the other nut with me because it looks like it might be a bit tricky to get back on the tab. Here's hoping for success in the morning!
