Several questions in response to my Vespa GTS 250ie cutting off. while returning home to my home on a mountain at elevation of approx 4000ft, my Scooter just cut off. After checking to see if I had any spark, I did not and also taking off the air filter, manuallymgiving it gas didn't help either. I was deadlocked but happened to check the ignition fuse (10amp) and it was blown. I immediately borrowed on from my truck and the scooter started. But, I suspect that what ever blew the fuse will probably do it again. Does anyone have an answer to this issue? I do use a Battery Tender Jr. Which has never caused a problem in the past but could this be a problem? Also, what does the engine light in the center of the dash indicate. It was on but once I got it started, it went off.
Final question- in worked through the helmet compartment and it was very difficult to get to the engine. How do you get the main cowling off to get to the engine?
Appreciate any help on these issues. Thanks......
