well got the variator off for et2 belt change (polini vari), but when i pulled it off, two ultra thin washers came off with it, and i cant remember if they were inside the variator, where the two pieces connect, or against on the outside of the variator as it mates towards the case
any clue
thanks
@starreem avatar
@starreem avatar
not exactly sure for your model, but for a GTS, there is a thin washer between the variator halves, it fits in the indentation on the back of the variator where it would contact the sintered bushing (some call it a gudgeon pin) the other thin one goes between the cup washer and the outer variator half.
from the outside towards the inside:
nut> cup washer> washer> outer variator> washer> bushing
[ Time: 0.0105s ][ Queries: 3 (0.0042s) ][ live ][ 334 ][ ThingOne ]
